Head Swap
Old Feb 10, 2010 | 07:48 PM
SApache40's Avatar
Default Head Swap
I am about to do a head swap soon and was wondering if I need to replace anything in the process. When I forged my motor I installed new lifter trays,comp cams OE replacement lifters,chrome-moly pushrods,thunder racing modified ls1/ls6 modified oil pump and a TR220. They now have about 40,000 miles on them and was wondering if I need to replace any of them when I swap my heads? I am going to keep the same cam.
Old Feb 10, 2010 | 08:02 PM
supersick99z's Avatar
No you don't need to replace that stuff again to swap heads
Old Feb 11, 2010 | 11:44 PM
mark21742's Avatar
When you put the new heads on double check your pushrod lenght to be sure
Old Feb 12, 2010 | 08:38 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Checking pushrod length is absolutely right. You need the heads configured to maintain or bump compression based off the cut pistons your running. Give us a call & we can help!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Feb 12, 2010 | 02:40 PM
mark21742's Avatar
I didn't see anything abput valve springs, if your still running the same valve springs after 40,000 I'd put new ones in if you have any kind of aggressive cam. I've heard "safe" valve spring life is anywhere from 10,000-30,000 miles depending on cam and what springs you are running.
I'd hate to reuse old tired valve springs to save a few bucks, then drop a valve in my new motor
Old Feb 12, 2010 | 05:19 PM
vettenuts's Avatar
Personally, for $20 I would drop in a new set of lifter trays.
Old Feb 12, 2010 | 05:37 PM
SOMbitch's Avatar
Head bolts if GM's tty's are on there now. Obviously HG's too.
Old Feb 12, 2010 | 11:05 PM
SApache40's Avatar
I agree and will put in a new set of lifter trays. What about the comp lifters and oil pump? I have a comp cam adjustable pushrod so I will check pushrod length. Heads have brand new dual valve springs and came with a new set of head gaskets. I have a brand new set of GM Head Bolts. Should I use ARP Head Studs instead?
Old Feb 12, 2010 | 11:48 PM
mark21742's Avatar
Honestly unless you want to drop the K member and motor to change a head gasket I wouldn't use head studs in an F-body. But I would recomend ARP head bolts. If you already have new stock bolts in hand use them, then the next time you pull your heads put in ARPs
