new stroker motor - low oil pressure! please help!
Hey so i started my new motor, and I only have like 5-10 psi at idle and 15-20 psi whn i revved it to 3,000 RPM
Before you ask:
i set 1/4" of clearance between the pan and pickup
i made sure that the o-ring went in fine
i ported and shimmed my new pump. (added washer under the spring)
yes the oil gallery plug is in the block
I cant figure this out for the life of me... everything else seems to run great!
Before you ask:
Just a suggestion. To check for mechanical oil pressure break off the upper plastic part of the oil sending unit drill and tap for fitting in mechanical unit and fire it up to see what you get. Sure it will cost you a sending unit but you will know the truth.
LS1Tech Premium Sponsor
What kind of clearance do your main and rod bearings have?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Verify with a mechanical oil pressure guage....if good replace sender....if still bad keep digging.
Assuming the pressure is in fact low its likely excessive lower end clearance or your lifters are possibly designed wrong and your hemorrhaging oil in every lifter bore. Not likely in a hydraulic....seen most of the problems there with some solid lifter designs.
-Tony
-Tony
Attachment 215059
It would be easier to tap it out here than to drill on your sending unit that might be good. If its good here then replace your sending unit. If not, carry on!!
Attachment 215059
Attachment 215059
and I built the motor... but i had my machinist size the bearings for me, and i installed them. this machinist is top notch, been in the biz for over 60 years.
the only thing i can think of is maybe when i put together the pump, i tightened the cover too tight? could this cause rubbing and damage the pump??
Very good. I think the rod bearing clearances are a little loose. .002-.0025.
