Old Feb 22, 2010 | 10:28 AM
19ls1ta99's Avatar
Default 233/239
Well i got a texas speed cam 233/239 .595/.603 112+2 LSA Bout to do the install on this andi was curious if any had any idea on if i would have to fly cut the piston heads. I have stock heads 7.4 push rods and 918 comp springs.
Old Feb 22, 2010 | 10:31 AM
big reg's Avatar
I had this cam in my old f-body and no flycutting was needed with stock heads.
Old Feb 22, 2010 | 10:37 AM
19ls1ta99's Avatar
fast reply and thanks good to know, did you have the car dynod with that cam?
Old Feb 22, 2010 | 11:59 AM
02*C5's Avatar
I know is a pain in the *** and I had a 232/238 600/600 and even though I still measured ptv its a way to make sure that "YOUR" set up is correct.
Old Feb 22, 2010 | 12:31 PM
19ls1ta99's Avatar
Ya thanks man i knew to check the ptv clearance i was just curious if anyone has experienced it and knew for sure
Old Feb 22, 2010 | 01:07 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Like they said, it's always a good idea to check and can save you alot of headache if for some reason the cam is installed off a tooth and the like. But, with a stock long-block and correct install, you should have plenty of room with the 233/239!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 22, 2010 | 02:20 PM
big reg's Avatar
When the car was dynoed, the stock clutch was slipping and I did not have an UDP. I believe it was in the low 390 rwhp range despite the above. Definately a good cam, sounded insane too. Here is a clip of mine when I had it.
[IMG][/IMG]
Old Feb 22, 2010 | 03:43 PM
butler's Avatar
my son had this cam in his 99 six speed car. Lt's ud pulley ls6 intake moser 9" 4.10 gears 390 horse.
Old Feb 22, 2010 | 04:06 PM
Michael02hawk's Avatar
I have a very similar cam, 234/238
...but, I'm running it in a stroked 383 LS6 block. With all supporting mods and a good non-slipping clutch, i put down 500 rear wheel HP!
But, based on "what i have read" I thought a 224/224 was basically the largest cam to be installed into a stock long block with stock heads, without the need to fly cut.
I measured my setup, with aftermarket JE pistons with reliefs (AFR 205 heads), and I'm pretty close on the PTV tolerances.
So definitely measure your setup!
Old Feb 22, 2010 | 09:13 PM
mark.deady's Avatar
224/224 i a small cam. there are guys runnign the tsunami cam from tsp on stock heads. also the ms4 is a huge cam and can be run with stock heads. always measure. i my self currently have the thp 233 239 on a 112 in my 2002 trans am. mods in sig. i made 408 401 with her. i need some better flowing heads i can expect a lot more. this cam is a monster and sounds great. you will not regret it at all. good luck with your choice and install. i will be posting a exhaust clip of it hear in the future... again good luck
mark
Old Feb 24, 2010 | 07:33 PM
Mikes96z's Avatar
I have this cam, no flycutting, RPM happy, great drivability
Old Feb 25, 2010 | 07:29 AM
19ls1ta99's Avatar
That sounds pretty nice , good to hear alota guys are liking this cam cant wait to get it put in
Old Feb 25, 2010 | 03:55 PM
airforcemanss's Avatar
how do you measure ptv clearances? how is drivability with this cam? any surging?
Old Feb 25, 2010 | 07:48 PM
LS1C5Vette's Avatar
I have that cam and had to flycut BUT I am running milled heads and bigger valves (ported heads) See below for numbers.
Old Feb 26, 2010 | 02:52 AM
ZachJ03's Avatar
I am thinking about switching to this cam as well. Should it be ok with my set up? My heads aren't ported, they are stock 799's.
Old Feb 26, 2010 | 09:45 PM
01'SSLSX's Avatar
free bump
Old Mar 30, 2010 | 05:30 PM
96RamAirTA's Avatar
i was looking into this cam... how will it work in a stalled auto with 3.73 gears. i was also wanting to do TEA ported 243's
Old Mar 30, 2010 | 07:58 PM
Hwystar's Avatar
I run the 233/239 in a stalled auto, I had TSP do a mail order tune, and they did fairly well. The car idles a little high, and has some surging issues every once in a while. Thats why my computer should be arriving at Frost's in the next day or two. I put in the Yank SS 4000 in Feb., and its not shifting right, and I'm hoping Frost can do away with some of the surging.
I'm running tis cam with Dart non ported heads and I didn't have to fly cut the pistons. I went from a Comp 224/224- 581/581, and wish I would've got the 233/239 first. I really like this cam with my setup.
Old Mar 31, 2010 | 07:20 AM
96RamAirTA's Avatar
well im currently in iraq right now so im thinking about doing this set up in the near future. i was thinking of just going cam first then later do the TEA ported
ls6 heads or PRC LS6 heads not sure yet but i got a circle d 3200 stall in right now. i might go a bit higher once i get the cam in like 3600-4000
Old Mar 31, 2010 | 09:25 PM
TXZ28LS1's Avatar
ive been really considering about stepping up to a bit more cam as well, just because my car is not really a daily driver. i have the X1 230/227 591/571 112 and it drives soooo smooth its crazy. Defintiely a great for a fun little street car. I am considering the 233/239 cam from TSP as well. It will probably be the largest cam i would run though.
