xe vs xe-r lobes, cammed guy come on in
I agree with speaking with PAC. PSI is another great spring manufacturer. As for the cam, you also need to compare the durations and intake closing angle at 0.004". I think that will be a bit more telling as it will determine when the cylinder will stop bleeding off intake charge.
a QUALITY single beehive can and will handle an aggressive lobe when setup PROPERLY. the more weight you pull out of the valvetrain means more stability assuming you have the proper pressure and setup. i have a hard time believing a inner spring is gonna save a valve at wot. just my .02
Ok well I have a xe-r lobe 224/232 581./.595 114 LSA running on a comp revised 918 single behive. Rated to .600. Do I have anything to worry about?? Car sees pretty regular use, and gets it's paces every once in a while. I don't beat on my car but I do give it the stick from time to time.
I ran PRC dual springs on a 233/233 .595/.595 112 LSA cam (XER lobs) for 45,000 miles with no problem....the springs were still good when I replaced them on the next cam swap. I installed another cam (XER lobs) and I have 80,000 miles on the Patriot Gold duals springs I have in the engine at this time..I'll swap them out over the winter and check how much life they have left ... car is a daily driver making 452/418 and now has 216,000 + miles on it. People who change out springs every 15,000 miles are throwing away their money. Unless you are running a large cam with a lot of duration and lift there is no need to swap out springs at such a short interval...If you do not believe me call Texas Speed and ask those guys how long they run springs in their daily drivers.
Race your car!
How you warm the car will have a large effect on spring life as well. If you're having good spring life, I'd be willing to bet that you are one of the few people that actually let their car warm up good before going out and beating it.
Just another factor in spring life, that alot of people overlook.
