Re-Sleeved Blocks
If you have a 1000 re-sleeves nationwide and say 100 of them are board members and 35 of the board members vote you have a sample rate of 35/1000 which gives a fair idea of what one might encounter with a dry resleeve.
Even ARE regarded by some as being able to do dry sleeves without problems had 3 out of the 8 people vote they had issues in the other thread on this.
Since the Darton Wet's are very new, most of the data is from the old dry sleeve set ups, which some people still consider due to the lower cost.
The poll data has 35 votes as follows
Problems from the start.................................12 votes..... 34.29%
Problems w/re-sleeve before 2000 miles...........4 votes......11.43%
Problems w/re-sleeve after 2000 miles..............0 votes....... 0%
No issues & less than 2000 miles .....................2 votes.......5.71%
No issues & over 2000 miles, please post mileage..4 votes.11.43%
I LOVE my RE-SLEEVE & I'd do it again!................5 votes..14.3%
I'd NEVER do a RE-SLEEVE again!.........................1...........2.86%
No issues but I'm afraid to actually drive it for fear it will have issues....1...2.86%
Get stroker instead based on my experience......3...... 8.57%
Aint saying anything because if I do they won't fix it.... 3....8.57%
Total Votes: 35.
Out of 35 experiences with re-sleeves 42.75 percent of the time the problem occured from the start or within 2,000 miles. No one has posted that a problem occured past 2,000 miles. I think this is a note-worthy trend.
Out of 35 people 23 don't seem all that happy with the re-sleeve experience or 66 percent of the people. That's about 2 of 3 for dry sleeves and all it takes for me to rule drys out.
If I ever go for the wet set up my top choices would be Steve, Scott & Wegner (if they decide to offer it later on) since they have extensive experience and the correct tools to do the job right.
We ran the same block in the vette late 2001 @ 800rwhp and street drove the car every day. Same engine ran in the Z28 with a cam change for 2002(8.70@154) same block crank and rods ran with the C5R topend in the entire 2003 race season (8.54@167). Mid season we lost a piston and hurt a sleeve, removed the existing sleeve installed new and finished season stronger than ever
( FACT NOT HEARSAY). Oh, we also ran the same head gaskets for almost 2 years.George Coffe's engine did have a craced block but had nothing to do with the resleeve proc., the block had a crack in the oil galery and we replaced the block no charge. The SBC was an economical way to go fast for George
Toms Block has a special headstud system (9/16) that we sell and the trq plate is required when checking bores for out of round. He did put the plate on and check the bores
everything came back to specs.
everything came back to specs.We learn something new every day, Nick is right. I obviously did not believe it at first or my engine would have been together by now. All the bores straightened out as much as 2.5 thou as ARE stated they would. Some things you just have to see with your own eyes, especially when you are planning on beating a block as hard as I do. The engine will be in the car by next Tues! I will be able to report the strength and durability of this block very shortly!
Thanks!
Tom
Moroso makes a sealer for use with antifreeze. The sealer is installed with no antifreeze in the system however. You should flush the system prior to use for best results. After it seals you replace the antifreeze. You do not leave this stuff in the system. Moroso All Weather Seal part number 35520.
If this doesn't work nothing will.
To answer your question about resleeving your block. Forget it. I remachined a dry sleeved block last year and will never do another. The dry liners are not installed on the crankshaft centerline or a precise 4.400" center to center distance as are the MID liners. There is not enough material left in the block to get the new liners where they are supposed to be. Get a new blem LS6 block or I can supply one if it comes to that.
Steve Demirjian
Race Engine Development
Rebuilt to a 4.135" bore by JD' Auto. Block seemed great, no leaks, etc...but assembly was not done correctly and bearings were shot at 1500 miles, spun bearing ended up with a broken rod and block was toast.
Option to rebuild to a 4.155" bore. For money and warranty concerns, not going to do this right now, but I will hang on to the block (6 sleeves appear to be salveable for another block). Trying something different that also involves a resleeve, will keep everyone posted.
By the way, I voted for "would have gone for the stroker instead" option. Although at this stage, the george C SBC way seems even better.
I hope your new setup works very well.
wet sleeves, 4.125 bore, 4" callies crank, JE pistons, manely pro-light rods...
