stuck between 2 cams need advice
TSP torquer V.2 specs are 232/234 595"/598" on a 112 lsa
OR
TSP Magic Stick V.3 237/242 .603/.609 on a 112 lsa
These are the mods i have right now..
pacesetter Lt's w/ory 3inch straight back
u/d pulley
96mm power typhoon intake w/95mm tb
4.10 gears
38lbs inj
m6
160 stat
OR
u/d pulley
4.10 gears
38lbs inj
m6
I would go with the Torquer V.2 for a DD,should get you in the 11's with the supporting mod's you already have.
Daily driveablility is not comprimised in my opnion at all with the Ms3, and i have 4.10's. I found a good tuner and have zero issues with drivablilty and 410rwhp. With stock 243 heads
For what its worth... Slap a ms3 in there with your stock heads, and run all over a Torq V2. with heads. Then wait to get a set of ported AFR 205's, least thats my plan
