Trick flow , MS4 and Fast 102 combo
One thing I didn't see mentioned is the fuel pump. If you still have the stock piece, you'll want a 250gph such as the one in the Racetronix kit. No sense in skimping on fuel supply when spraying 250hp+ on a $9k motor.
Jason
Jason
I don't mean to be rude, but are you serious that you don't know how to check for the correct pushrod length? That is almost as basic as you can get.
You got new pistons, but are you going to have the new rotating assembly balanced?
It sounds like your buddy is going to be pushing this motor hard, do your buddy a favor and get some experienced help with putting this together. It might hurt your ego, but there is more to making a motor perform, and last, that simply bolting on the heads and slapping in a cam.
I know what i'm doing this isn't the first time that i prepared a car .
answered above
I wasn't trying to flame or instigate. If you have someone building the motor, then they should be the one measuring for correct pushrod length and rocker arm geometry as well as piston to valve clearance amongst a multitude of other measurements. It's a pretty important measurement, and as long as you have someone who knows what they are doing, it's not an issue.
All we are saying is, usually, you don't order pushrods until you have the heads bolted up, and the cam degreed, and the rockers adjusted for the correct swipe over the valve stems. Granted, it's a hydraulic lifter, but just look at how many threads are posted when people just 'guess' at pushrod length and then have issues with hanging a valve, or a noisy top end.
Don't rush it, or that $10,000 he spent can turn into another $5000-$10,000 easy if he grenades the motor.
I'll cancel the pushrods . It doesn't matter what type of kit the nitrous it is both ways you need to add fuel either through tuning or through a solenoid!
Maybe you should spend sometime over in the nitrous section researching and asking some question over there, you would get better feedback I am sure.
Just my .02 I am running 36lb injectors right now N/A.
