will a 03 z06 cam go in my 98 ls1?
Ok I got a line on a 2003 zo6 (ls6) cam, springs and push rods guy just pulled them out of his car and put a hot cam in. will they fit do I need to use all the listed parts and is there any other parts I will need to change as well? and yes I know another cam thread!
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would only use that cam if you were thinking about going boosted. Don't ever get used springs. You really never know what kind of rpms they have seen or mileage. Just looking at them won't tell you anything either. Springs and pushrods are 2 of the cheapest internal engine upgrades you can do in order to strengthen your valvetrain. If he is giving you then cam, sure, it will work/fit. I wouldnt go to the trouble to do the swap unless I had an incon twin kit sitting right there though.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
But to answer your question you need a few more things. Coolant, springs, pushrods, a couple quarts of oil, new balancer bolt....just to name a few things. And if you are doing the swap yourself make sure you have several 10mm sockets that are good quality. I have mushroomed a few over the years trying to tighten down the rockers.
well the reason is because I didnt really want to go with some crazy cam and ls6 just seamed like a good choice I drive this car everyday I want and need it to be reliable. thank you for your help!!!
That "junk" cam trapped 96.5 mph in my bolt on only (at the time) z06 in the 8th. I would say thats pretty good. I also swaped it into my trans am when i pulled it out the z06. I just put in the cam, springs, push rods because I knew the miles/history and since the TA had some miles on it I replaced the oil pump and timing chain. If I had it to do over I would still do it again, I didnt do the mod expecting 50hp increase, I knew what I was going to get when I did it and I was fine with it. On the stock tune it drives just like it did before the cam, just more pull up top.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
He probably meant 25 flywheel hp, but numbers are subjective depending on what dyno your on. The TR224 has more duration and lift than your LS6, so obviously you would make gains. I doubt you'd be 440 rwhp plus on 'most' dyno's, cause your 417 rwhp with an LS6 cam is already more than most expect or see with a stock LS6 cam. 417 rwhp with bolt ons and an LS6 is already a small miracle in itself lol.
7757227580
ok so Im getting the cam for 200. now since you guys seam to know quite a bit about cams this is what i want. I want about 50 - 75 more hp out my bolt-on only car with a cam and a port n polish on my heads. I dont know about cams at all! I dont trust my buddy who is helping me to tell me the truth on what Im looking for! he's that guy that will have me build another of my barley streetable car, cause thats how he is. there is a S 2000 with a big turbo that I want to eat some of my N/A rubber. and summit is 3 mi away from me.
ok so Im getting the cam for 200. now since you guys seam to know quite a bit about cams this is what i want. I already have a 500+ hp built car that I got at an auction for 7500.00. lucked out I know. I only know it has low vacuum and wants to die at every light. that is not what I want!!! I want about 50 - 75 more hp out of a cam. my buddie is going to port n polish my heads for next to nuttin and help me with the install of all. I dont know about cams at all! I dont trust him to tell me the truth on what Im looking for! he's that guy that will have me build another of my barley streetable car, cause thats how he is. there is a S 2000 with a big turbo that I want to eat some of my N/A rubber. and summit is 3 mi away from me.
If you are talking about putting a ls6 cam in the "500+ hp" car and looking to INCREASE power think again. Sounds like it needs a tune, you would be suprised what a good tuner can do.
