LS1 Hotcam Pass Emissions?
Old Dec 31, 2003 | 02:00 AM
BlkBrdWS6's Avatar
Default LS1 Hotcam Pass Emissions?
Hey guys! We have the sniffer with the roller dyno thing in MO. I was wanting to put an LS1 Hotcam in my WS6 along with some TTS Longtubes with cats and GMMG catback. If I would get a good tune, do you think I could pass the sniffer? Thanks for any opinions and info!
Old Dec 31, 2003 | 03:38 AM
beardWS6's Avatar
Check Sig, I passed with X1 Cam and all in Texas!
Old Dec 31, 2003 | 05:44 AM
mcflyz28's Avatar
I'l find in July, not expecting any problems.
Old Dec 31, 2003 | 06:28 AM
TaTommyWS6's Avatar
I think with a good tune, a raised idle, and your cats in the stock position (not moved further away from the engine because of LTs), you should be ok.
Old Dec 31, 2003 | 09:45 AM
SSCamaro99_3's Avatar
It is OBDII in MO. If you get a good tune, you should pass the computer, and be on your way.
Old Dec 31, 2003 | 03:40 PM
RhinoTA's Avatar
I was wondering the same thing....im in chicago, which is the sniffer with dyno.
Old Dec 31, 2003 | 04:46 PM
The only way to pass a roller test is with cats. No cats and you best have the worlds best emissions tune, and pray.......HARD. We hooked mine up to a sniffer for fun. Wasn't even close.
Old Dec 31, 2003 | 05:33 PM
ss rally red's Avatar
I have been doing ET in Ga for almost 6 years at our shop, 96 and up cars get OBDII testing which we all know can be passed with LS1 edit with almost any setup(we have NO visual inspection on OBD cars here) just for fun I ran my 02 with Lt's ORY, hotcam(see sig) in manual mode and it would pass the levels set for 95 LT1 cars! These were the last standards available of course because after 96 25/25 and 50/15 testing was not required. It was close on NOx because of no cats but would pass HC & CO, which was suprising.
Old Dec 31, 2003 | 05:39 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Exclamation
No it's not.
IL has 8 counties total that test. All of these counties use OBD scan test only for '96 and newer cars. And yes I'm sure of this. All you have to do is pass the scan test, nothing LS1 Edit can't take care of for you...
The I/M240 crap you are thinking of is for '81-'95 cars. Pre-'81 are sniffer only (no dyno)....
Old Dec 31, 2003 | 10:15 PM
MUSTANGEATER's Avatar
The Gateway STL Clean air act is so pathetically Easy to pass. You don't even need to tune your computer for performance but just turn off all your SES codes and delete prior history. Personally I wouldn't get those TTS headers. If you want Tuning I would contact Mark@ Raging Motorsports 913-814-RAGE or Ron@ Davinci Motorworks 618-222-1201 if you want any local help.
Best of luck
Floyd
Old Jan 1, 2004 | 03:17 AM
RhinoTA's Avatar
Originally Posted by RPM WS6
No it's not.
Thats good to know....I assumed it was both because I used to have a 98 civic and they ran it on the dyno thingy, or I/M240?
Old Jan 1, 2004 | 09:16 AM
RPM WS6's Avatar
Yes, because up until 2002, they still used I/M240 even for '96 and newer cars. But that pratice is no longer. OBD scan only for '96 and up now.
You must have had your '98 tested in early '02. When I had my '96 Bonneville tested in May of '02 it was OBD scan only.
They still pull the cars up on the dyno to plug into the PCM, but they don't actually put anything in the tail pipe or run the car on the dyno ('96 and up).
Old Jan 1, 2004 | 10:43 AM
TA2SLOW346's Avatar
Do they check to see if your vin# in the pcm matches the one on the car?
Old Jan 1, 2004 | 10:49 AM
RPM WS6's Avatar
I don't know.
I've never tried to pass one with a non-matching VIN???
Old Jan 1, 2004 | 03:11 PM
Nope, they only check that car's VIN #, Your Registration, and then They give you the gascap test and then the Scan test for Current and Past Codes. If you fail the scan test you take the pre 96 roller test w/ the dyno.
Old Jan 1, 2004 | 11:45 PM
RhinoTA's Avatar
Lightbulb
Yep, I had it tested in '02, i cant remember when, but it was definetly early in the year. Thats really cool though, Ive almost disregarded getting cam and headers thinking i would be screwed come test time. Thanks for that info! looks like its time for some Rumpity Rump!
Old Jan 2, 2004 | 12:16 AM
RPM WS6's Avatar
Actually, even in states that still do tail pipe testing many cams will pass if you run cats. Emissions testing should not keep anyone from doing cam & headers, just keep in mind that if your state still does tail pipe testing you'll need cats and a mild to mid sized cam. Any 224/224 114lsa or smaller cam should pass the sniffer with cats.
Old Jan 2, 2004 | 12:24 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
I tested my 99 Tahoe this summer and they just plugged into the OBDII port on the truck.
I have heard of 2-3 hotcammed LS1's passing even the rollers around Chitown.
Old Jan 2, 2004 | 12:28 AM
RPM WS6's Avatar
How'd they get a roller test? Were these tests in early '02 or before? Or did they opt for roller after failing OBD scan due to codes?
I think they are no longer offering even the option for roller tests on '96 and up cars as of 1/1/04. You must now pass the scan.
Old Jan 2, 2004 | 02:54 PM
RhinoTA's Avatar
Thats cool....I do plan on keeping cats in the scenario. Ive got that loudmouth exhuast so i figured cats would help keep the noise at a reasonable level with headers.
