Machine my ASP crank pulley for a F-body using a Rollmaster double roller ?
I think you only have to machine it for the SLP timing set. Although I don't know all the details on "every" timing set out there.
Originally posted by I8COBRA:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> I have the ASP and Rollmaster double and didnt need any machining. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll ditto that answer as I have the same. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
My ATI balancer had to be turned down on a lathe to clear the SLP double roller, not sure if this is true with your setup.
my ATI fit w/ no work needed. if you look @ the back of the lower gear for the rollmaster, and compair it to the stock lower gear, you will see that the R/M has a recess so it will slide on a little farther on the snout of the crank. best way to check, is measure the snout of the crank sticking out from the front edge of the lower gear. then install the R/M gear and measure again. should come out to the same. dont just set both gears on a flat surface and compair, the R/M will look taller.
LS1Tech Premium Sponsor
Nope, no machining is necessary. I have the Rollmaster double-roller timing set on my SS.
FYI, we stock the single, double-roller, and heat-treated double-roller Rollmaster timing sets. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Trevor - Texas Speed & Performance
