Wont Start after cam install
In the 1970s this advice would be spot on correct. However, with the complexities of todays modern engines and their electrical systems, it is completely useless.
P0108:
http://www.hotrodlane.cc/New%20LS%20...TC%20P0108.htm
below is a video of her starting up you can hear the multiple backfires when she starts up. i adjusted the throttle screw so now she fires up with no problem but as soon as i try to let her idle she starts to backfire. I have a small cam i've heard of people running much bigger cams with stock tuning, i tried posting in tuning and diagnostic with no luck, so i was hoping yall might have a few ideas. I have a hp tuner coming on SAT but all i really need is for her to run enough to get to the tuners.
http://www.youtube.com/watch?v=-oXXhhhIn2g
idk sounds like it should idle. not knowing much without being there, i would say you should try clearing the pcm and doing the learn procedure once again but really try to get it to get idle on its own. is the MAF facing the right direction?
Take off the sparkplugs and make sure they are all gapped right. Sometimes when you put plugs back on, and if it was difficult to put on, the gap closes. This may cause that. I dont remember if you said that you put new plugs on, but try doing that too.
