Wont Start after cam install
#61
I went with stock ls1 lifters just ones with lower mileage, the pushrods are 7.4 comp cams hardened. i used stock parts and sizes so that i wouldn't run into these problems.
#62
i know it's obvious but somethin is wrong. here's my vid of my first and second start up with a 227/224 cam and new 241 heads with new pushrods, lifters, timing chain, oil pump and pulley i had to keep it idling at almost 1000rpm at first so it wouldn't die but once i got the hang of it i could rev it only to 800rpms and i was golden.
http://www.youtube.com/watch?v=msFNEqiavHU
http://www.youtube.com/watch?v=dZ9G6LuHnGM
this was with stock manifolds and cats a stock stall on a tune that was only meant for a LS6 manifold as a mod lol so really a stock tune engine lasted 300 miles till it hydro-locked lol oh well time to get a better engine. good luck to you OP!!
#63
your pushrod length is not the issue, there is no lash to set, just bolt them down and go. id be looking twords a compression test. and checking out that injector. either swap it out without with another one and see if the problem follows, borrow one of the same size from a buddy or if you have access to tuning software you will be able watch the duty cycle.
#68
I've checked the compression and its getting good compression so my next step is to check the injector. been so busy with work that i haven't had much time to work on her. I'm going to switch the injector with another one to see it could have possibly been stuck open. i'll keep yall updated.
#70
I'll pull the rails in the morning but in the mean time I did some research and some people have had a cylinder misfire because of a faulty o2 sensor even without them throwing a code. has anyone else heard of this?
#78
After switching the injectors i finally got the code to jump from cylinder 1 to cylinder 3 so i've got the injector coming in today gonna put it in and see what happens
