Wont Start after cam install
Old Mar 18, 2010 | 01:41 PM
  #41
banditz28's Avatar
I think that im going to go and take it apart and double check the timing chain just so I can rule that option out. thanks for the replies and I'll keep yall updated.
also taking the timing chain cover off would that mean i have to change the cover gasket again?
Old Mar 18, 2010 | 01:47 PM
  #42
01ssreda4's Avatar
The metal type gaskets are reuseable. However take this with a grain of salt as after 100k they seem to need replacing. Otherwise, if all is well it should seal back up fine with a used gasket.
Old Mar 18, 2010 | 02:02 PM
  #43
banditz28's Avatar
well the gasket has only been on there for about a week with very little run time
Old Mar 18, 2010 | 02:08 PM
  #44
01ssreda4's Avatar
^^ well you're good then
Old Mar 18, 2010 | 02:48 PM
  #45
pauls99z28's Avatar
Well im glad you decided on double checking timing. it could be off by a tooth and that makes a big difference.
Old Mar 18, 2010 | 04:17 PM
  #46
SWEET98SS's Avatar
If I were you, I would take pictures of the gears and the dots so we can take a look at how its lined up to rule it out.
Old Mar 18, 2010 | 04:43 PM
  #47
disc0monkey's Avatar
but i thought it idled fine at one time?
Old Mar 18, 2010 | 10:38 PM
  #48
Blowngtx's Avatar
yea it did idle fine at first. fired right up and stayed at a decent rpm. around a grand or so
Old Mar 18, 2010 | 10:53 PM
  #49
lmt0705's Avatar
is every cylinder firing?
Old Mar 19, 2010 | 08:28 AM
  #50
banditz28's Avatar
I should be able to get the cover off tonight after work I'll post some pics to see what y'all think
Old Mar 22, 2010 | 12:05 PM
  #51
banditz28's Avatar
I finally got the time to check out the timing and like I said before everything is dead on. so i put everything back on and she fires right up and idles perfectly for about five minutes. it started with one backfire then it started doing it pretty rapidly. i shut the car off and try to restart it and it struggles to restart after about 30 secs of trying it starts and a code finally pops up p0301 which is misfire cylinder 1. so i pull cylinder 1 plug check it and it looks pretty toasted, so i replace it fire it back up and am back where i was at before a lot of backfiring.
Old Mar 22, 2010 | 12:25 PM
  #52
lmt0705's Avatar
what do you mean by toasted? put a pic up if you can.
Old Mar 22, 2010 | 12:30 PM
  #53
banditz28's Avatar
the plug looks fouled. burnt at the tip and was only ran for less than 5 mins
  #54
lmt0705's Avatar
do you have another coil pack you can try with a different wire? check wiring to the coil, compression and the injector. not much else it can be. do you have tunimg software? if so it should be easy to see whats happening on that cylinder
Old Mar 22, 2010 | 01:01 PM
  #55
thunderstruck507's Avatar
trade plug wires to another cylinder if you don't have an extra...see if the code follows to that cylinder
if not swap coils to another cylinder
Old Mar 22, 2010 | 01:24 PM
  #56
banditz28's Avatar
I just finished swapping plugs at first then fired her up, the misfire cylinder 1 code still came on. so i swapped the coil packs with no luck the code just keeps coming back.
Old Mar 22, 2010 | 01:58 PM
  #57
good point if they arent new wires chances are they are all effed up. happened to me once.
i went to autozone bought the cheapo lifetimes and ill change them every time i take the coils off.
Old Mar 22, 2010 | 02:07 PM
  #58
lmt0705's Avatar
you need to check compression and also you may have an issue with that injector, could be stuck open. is the plug white or black and carboned up? what do you mea by burned?
Old Mar 22, 2010 | 02:51 PM
  #59
banditz28's Avatar
The plug is black and carboned up after maybe 10 mins of total run time. how do you check the injector? and the compression check was going to be my next step
Old Mar 22, 2010 | 03:04 PM
  #60
are you sure you lashed the lifters properly?
