2001 Z06 cam swap
Long story short, I'm consider a Z06.
Is the 01 Z06 suited for a huge cam, to make it more of a beast than the 2002? I'd be looking to increase acceleration more than top end speed (I rarely go over 100 mhp)
Or should I just try and get a 2002, as that cam is as good as it gets?
Thanks for the advise
Paul
A 2001 Z06 would do me very nicely indeed then.
Thanks for the info, and sorry about my current ignorance about camshafts
hope to change that soon, and thanks for the guidance for a cam too Last edited by FUN LS1; Mar 21, 2010 at 12:36 AM.
Cheers for the advise
Paul
To the OP, I personally ran a 232/232 600/600 in my stock ls6 for several years till I broke the timing chain. The things that make a 02+ z06 better than a 01 are all the bolton stuff you are going to do. The factory 02 cam is slightly larger, they deleted the precats in 02. Headers and xpipe are going to change the cats or get rid of them completely. An after market cam is going to way bigger than even the 02 cam.
The only thing that you wouldnt change in just bolt on stuff is exhaust valves in the head. The 02+ cars got hollow exhauts valves. If there is any gains hp wise its minimal at best.
[EDIT] Why would he keep the stock valve train? Because he already said he liked 2001 stock cam, and maybe he doesn't really want to worry about replacing after-market springs every other year or so. So if you're keeping the stock valve train, how high would you try to lift the valves? Sorry if I made you very anxious...but the whole point was about stock-like cams...
You may be better off selecting a combination of parts that makes more torque than horsepower, commonly referred to as "power under the curve" in this forum. You can make significant gains with cams in the 21x to 22x range of duration. They may not have the agressive choppy idle that so many people desire, but strong performance on the bottom end usually doesn't come from that style of cam.
Also, I noticed your bolt-on mod's to your TransAm did not include headers. Are there strict emissions requirements in your area? I am sure you are aware, but many of the same performance upgrades can be applied to your current car to make similar power. Headers, Heads and a camshaft change can net you 100+ rear wheel HP over your current configuration.
That's good to hear, I wouldn't really want a huge choppy idle, 'power under the curve' is more what I'd want to aim for.
As for emmisions in the UK, I would need to keep cats with LT to stay legal, OR go to one of the many 'friendly' emmision testers
, who will pass my car without cats. Problem is, I plan to move abroad when the housing market picks up, and I wouldn't know any friendly testers there, hence why I'd go with cats.I was intending to finish the exhaust, but I'm now thinking the Z would be a much better car for me, as the roads where I live a narrow and twisty, and even with Konis, the WS6 just doesn't handle as well as I'd like....
Thanks for all the advise,
taws6, hammertime and silver408z are offering good advice, use their replies to make an educated decision on what you want to do.
