MS3 = what compression ratio?
Old Mar 26, 2010 | 08:51 PM
MetallicaMatt's Avatar
Default MS3 = what compression ratio?
I'm running the MS3 cam in my 02 WS6...any idea where my compression ratio is?
Old Mar 26, 2010 | 10:12 PM
Paint_It_Black's Avatar
Same as it is stock.
Old Mar 26, 2010 | 10:31 PM
Damian's Avatar
LSX Mechanic
Cams don't change static compression.
Old Mar 26, 2010 | 10:39 PM
00fastta's Avatar
compression ratio has absolutely nothing to do with the valvetrain. A compression ratio is when BDC is compared to TDC. BDC in this case is a value of TDC i.e. x1:1 where 1 is the size of the space at TDC compared to the space at BDC which is denoted by x1 where 1 is the space at TDC and x is the coefficient of how many times bigger the space is at BDC. Valves do not change that. combustion chambers sizes, and stroke control that.
damn college is turning me into a nutcase.
Old Mar 27, 2010 | 01:12 AM
what are they stock? I never bothered to look it up.
Old Mar 27, 2010 | 02:17 AM
http://www.smokemup.com/tech/ls1.php
Old Mar 27, 2010 | 03:15 AM
brian_rs/ss's Avatar
whoa hold up...you have 2,000 something posts, a ws6 and a 730hp vette...but u didn't know that a cam has no effect on static compression?
Old Mar 27, 2010 | 09:15 AM
butler's Avatar
longer duration cams lower the cold cranking compression but not compression ratio.
Old Mar 27, 2010 | 09:32 AM
brain fart (plus I was looking at cranks)...posted it, left the house, then realized I was about to come home to a flame LOL
Old Mar 27, 2010 | 11:29 AM
Damian's Avatar
LSX Mechanic
You can change cranking compression/cylinder pressure with camshafts FWIW.
