Cam suggestions??
Old Jan 3, 2004 | 01:25 PM
SSEUL8R's Avatar
Question Cam suggestions??
Well... I want a cam that will make about 400 to 410 rwhp on stock heads. I want a nasty idle, I dont have to pass emissions, and I dont mind changing springs every couple years or so, wont see much if any n20, and I dont want to spin it up past 6600. I was looking at the TR230, X1, and the TSP 232/228. I've also looked at the Comp 228/230 on High Lift lobes. But Im not limited to one of these, Im open to any suggestion. Which cam has seen the best results? Also, would any advance be beneficial? Thanks
Old Jan 3, 2004 | 01:30 PM
Taspeed's Avatar
Try a reverse split. I had unported 5.3 heads w/2.02 1.55's and an F1 spec'd comp grind. I made 438rwhp 418 tq with stock gears and mac headers. Reverse cams can make a lot of power, but are best used with 4.10's.
F1-.591/.569 230/226 112 Normally this is a lunati grind, but i ground it on xer comp lobes with 0 advance ground in.
Old Jan 3, 2004 | 01:41 PM
jrp's Avatar
jrp
SN95 Director
all those cams listed will help you reach your goal, click the 230 link in my sig to here that nasty idle .
Old Jan 6, 2004 | 10:55 PM
SSEUL8R's Avatar
Ttttt
Old Jan 6, 2004 | 11:08 PM
goinbroke's Avatar
The tsp 231/237 will definitly get you 400 to 410. I think it is a proven cam.
Old Jan 6, 2004 | 11:09 PM
GrannySShifting's Avatar
I have one that can get you 419 rwhp
Old Jan 7, 2004 | 06:22 AM
chris98pace's Avatar
Yea?? well come on now and put one in my car. My finger is itching on the buy now option with the TSP cam.............get me your cam and stop me from buying that one.
Old Jan 7, 2004 | 11:02 AM
CamaroCain's Avatar
TSP 231/237: https://ls1tech.com/forums/showthrea...ight=231%2F237
This is the cam I plan on running in my car. It's nice to see the good dyno numbers but I care more about track numbers. With this cam and a good tune I should see great results, and it should work great with my high stall.
Old Jan 7, 2004 | 12:51 PM
DAPSUPRSLO's Avatar
You could try mine. 230/236 576/573 107lsa 107icl. I'll let ya know how it does when I dyno
Old Jan 7, 2004 | 01:40 PM
i already have it on order for you? am i not supposed to?
Old Jan 7, 2004 | 04:20 PM
Cool deal i will give you guys a call.
TH-400,cam,battery relocate,ac delete and new exhaust. Damn the list is growing.
