Need help diagnosing ticking (Video)
When driving to work, I noticed the oil pressure start to fall down to around 16-20psi from the normal 35-40psi idle. I immediately parked the car and did not start it back up for a few hours. Upon leaving work, the service engine light came on and the car started to sputter and run like **** for about 60 seconds before I parked it. At this time, the "lifter tick" was very very noticeable at idle and under any type of load...oil pressure seemed okay though. Bent valve, pushrod, collapsed lifter? Is that basically all that could be contributing to the valvetrain noise besides maybe a broken spring or rocker? Could one of these be the source of the low oil pressure? I was told that if it was a spun bearing, the ticking noise would not increase with RPM but stay somewhat consistent while the RPMs were increased...is this true? I know there is no way to really tell what is damaged until you tear into the valvetrain, however, could a lifter or something else caused more damage to the pistons or something else?
Car has 67k miles on it.
Thunder Racing 230/224 .575
918 Springs on factory 241's
Thanks in advance for any help or advice!
http://s296.photobucket.com/albums/m...t=M4H01468.flv
http://www.youtube.com/watch?v=uBlUSUXUaVw
#6 rod bearing was paper thin, when the motor got torn apart last week. Luckily, I didn't trash the crank though.
That doesn't sound that expensive
