i dropped a bolt in the oil pan!!!!!!!!!1
The same thing happened to me. I was stupid enough to drop it twice. The first time I was able to get it right out with a flexible magnet, but the second time it rolled all the back passenger corner. I unbolted the oil pan, took out the sensor in the side and also tried to get it out of the drain plug with no luck. After about 3 days of trying and getting frustrated, my son was able to get it with a long magnet. It was stuck on the top of the windage tray. When I finally got it out, I mtied string around the bolt and put rags in the pan so it would not happen again. Good luck, with patience you will get it out.
Ive been out there trying for about 2 hours with a flexible magnet and a small flash light and nothing. Ive put the magnet all the way down by the actual screen and still nothing, im starting to consider just leaving it in there and getting another bolt
i was trying all morning with a small flash light and a long flexible magnet. the bolt was on the right side of the pan right near the drain hole all the way at the bottom of the pan... yea i wont do that again
I had one fall off on me in my 98 z28 I owned a long time ago, Did it outside in the 22 degree weather, Fingers went numb dropped the bolt, Fished for about 30 minutes an said screw it. t still running great, The bolt is too heavy to get sucked up into the pump or it the crank, Itll be fine leave it in there if you cant fish it out.
