Guess the heads?
Old Apr 1, 2010 | 04:36 PM
SOMbitch's Avatar
Default Guess the heads?
Let's hear it. I think you will be surprised
Old Apr 1, 2010 | 04:59 PM
outkast6991's Avatar
243's???????
Old Apr 1, 2010 | 05:04 PM
regblkss's Avatar
cnc 5.3 heads
Old Apr 1, 2010 | 05:08 PM
SOMbitch's Avatar
Originally Posted by outkast6991
243's???????
Good guess but nope........
Old Apr 1, 2010 | 05:10 PM
hand ported 241's??? come on man your killing me
Dragkid1917's Avatar
241's?
Old Apr 1, 2010 | 05:13 PM
Bill'sWS6's Avatar
Absolute Speed
chrs1313's Avatar
241s....
venom99's Avatar
853 head
Old Apr 1, 2010 | 05:14 PM
SOMbitch's Avatar
Well, they are not ported but have some handwork on the valves and seats.......
Old Apr 1, 2010 | 05:17 PM
well you have my attention now. my new motor has a set of 243's with a nice VJ and some bowl work(unported runners). i''d be very happy if they keep up with your numbers
Old Apr 1, 2010 | 05:20 PM
ss454327's Avatar
317s...
Old Apr 1, 2010 | 05:28 PM
chrs1313's Avatar
TFS 220s as cast with a little tooley massaging...
we are all assuming 3.90 bore heads if they are for 4.00 bore or bigger that should be listed...
plus flow numbers can be generous on certain machine what did a stock head flow...
Old Apr 1, 2010 | 05:58 PM
SOMbitch's Avatar
WE HAVE A WINNER Haha!!
3.90 bore with a pipe on the exhaust.
Two things really surprised me.... They flow a little better at at some lower lifts than the CNC 215's and they picked up 50cfm at .600 on the exhaust over the advertised "as cast" #'s on the TFS website. The car is at RPM and will be tuned tomorrow.
Anyway I was really impressed with the #'s and hope the track will back it up. I had mid-high 11's HP with the old setup but only ran a best 12.02 so we shall see...... The fact that it is lowered with heavy wheels doesn't help my times but it is used as a streetcar with runs down the 1320 for ***** & giggles
Old Apr 1, 2010 | 06:17 PM
chrs1313's Avatar
yup i was impressed with the numbers too, i just helped someone flycut for those heads with a polluter car...they are running the same 57.5cc as my heads...TEA said they were going to mill them to 59CC but when we checked last weekend they were 57.5cc...so you might want to make sure you check PTVC, not sure if you are milling or not...
great bang for the buck...also the added porting was very cheap too...
Old Apr 1, 2010 | 07:29 PM
SOMbitch's Avatar
Yeah this scares me a little bit.... Mine are supposed to be cut to 60.5cc to bump me to 11.2ish. The heads are already on so I guess I'll find out one way or another..... I hope the same guy didn't do the milling on mine
Old Apr 2, 2010 | 08:38 AM
rob69zombie's Avatar
Hey SOMbitch- nice meeting you the other day in @ Advance in Morehead. That car is impressive and clean. Good numbers!
-Josh
Old Apr 2, 2010 | 04:30 PM
SOMbitch's Avatar
-Josh
Thanks Josh! Enjoyed meeting you Joe (IIRC) and Jamie too I couldn't resist stopping when I saw 3 GORGEOUS F-bods parked next to each other. I didn't really need that injector cleaner I just had to stop and look at you guys cars
Old Apr 2, 2010 | 05:33 PM
garygnu's Avatar
what intake are you using?if it is a fast do you open it up to check port alignment?
Old Apr 3, 2010 | 08:18 AM
SOMbitch's Avatar
Yes it is a FAST 90 and no I didn't check the port alignment. I am getting it ported in the next couple months and will check it then. Maybe have to look into the chrs1313 trick......
