Knife Edging and crank weight reduction
Old Jan 5, 2004 | 07:27 AM
Reckless's Avatar
Super Moderator
Default Knife Edging and crank weight reduction
Has anyone attempted to lessen the weight of the rotating internals by knife edging the crank weights or some other method. It seems with the advent of all the solid roller combos lately that this may be the next step?
Old Jan 5, 2004 | 09:25 AM
AP-Engineering's Avatar
Knife edging a crank is generally done for windage purposes. To help it lower windage in the crank case. As a weight reduction, I am not sure how much it would take off the crank. As for lightning cranks, i am all for it as long as you don't hurt the strength of the crank. Sometimes people have a tendacy to get carried away and by doing that reduce the strength of the part. If strength is equal, the lighter the better.
Chris
Old Jan 5, 2004 | 09:28 AM
JF WS6's Avatar
I've wondered about this too. I've never heard of anyone knife edging an LS1 crank but I hear about import engines doing it all the time.
Old Jan 5, 2004 | 12:43 PM
Scalpel's Avatar
I thought the LS1/6 Lunati cranks were knifed edged for the exact reasons Diamond posted?
Old Jan 5, 2004 | 12:47 PM
LOnSLO's Avatar
The Lunati cranks are all knife edged to cut down on windage, or resistance, in the crankcase. The Callies brand cranks have a more rounded edge on the weights.
Old Jan 5, 2004 | 02:55 PM
DynamicZ28's Avatar
so any more info on this?
I also wondering about lightening a crank also
Old Jan 5, 2004 | 06:54 PM
DaleMX's Avatar
If you lighten the crank without changing the weight of the pistons and rods I believe it will throw the balance off.
Old Jan 6, 2004 | 09:33 AM
DynamicZ28's Avatar
ok great, so has anyone had their crank lightened and been able to run it and had no failures
Old Jan 6, 2004 | 09:39 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
AMS in Louisiana lightens a bunch of stock crank up for the super stockers and others. You might find out what they can do for an LS1.
Old Jan 6, 2004 | 12:51 PM
DynamicZ28's Avatar
do they have a website?
Old Jan 6, 2004 | 11:56 PM
KHShapiro's Avatar
the Lunati cranks have rounded edges and the weights are not true knife edges.. Knife Edging is costly .. when i ran gen1 SBC's i Knife edged all of my cranks ..But with the LS1's i havent felt it was needed. As Far as lighning hole or Direct feed holes i am all for that, just have someone that is good do it if the Crank didnt already come that way.
Old Jan 7, 2004 | 04:52 AM
bigeller's Avatar
I currently have a 6.0 crank in my LQ9 6.0 in the Z28.. We recently tore several engines down and weighed the cranks.. The LS1 crank generally weighed 50 lbs.. The 6.0 cranks weighed 51-51.5 lbs.. Assumming the LS1 crank was balanced with the stock 4.00" 6.0 pistons/rods etc., how much power would that extra 1-1.5 lb lighter crank be worth in your opinion? I mean that's an extra 1.5 lbs spinning to 6900 rpms I've got right now.. I've always wondered this? Probably hard to put a number on. but has to be worth something right?
Old Jan 7, 2004 | 11:14 AM
DynamicZ28's Avatar
@6900 rpms it may not be as beneficial as it would be @8000 rpms, plus in conjunction with light rods(aluminum) and a light piston, I think it would be of value. Value meaning longevity, the ability to spin the motor faster..prolly will equate to a couple horsepower, but if it affects the integrity of the crank it probrably isn't worth it
Old Jan 7, 2004 | 11:21 AM
Also remember that with the LS1's the crank is up in the block. It does not hang below the oil pan rail like a gen 1 SBC. By the crank being up in the block helps with windage in the crank case. I am not sure if most people on this board with what they are doing with there LSx engines, would benefit from knife edging a crank.
Chris
Old Jan 7, 2004 | 11:27 AM
Country Boy's Avatar
Senior Member
In the case of the 6.0 crank... It may be heavier due to being solid and not driiled through the main, but you also have to remember that the extra weight of the 6.0 crank is in the center which is neutral when rotating. People try to stay away from the 6.0 cranks because they are supposedly heavier because they are solid, but the weight is neutral because of it being in the center
Old Jan 7, 2004 | 11:29 AM
KHShapiro's Avatar
while i am not sure about the overall performance of knife edging as in refreance to weight i do know that it was benical in the SBC in the drag but i dont believe it is an issue in the LS1's with how the crank is so high. Light weight cranks are great but ours isn't that heavy to begin with.. An Aluminum rod it great if you plan on changing them every 100 passes or say 7k-10k miles.. The Aluminum rods Strech, now when you order a set of pistons you need to let them know they are for Aluminum rods and they will figure in the strech of the rod when they make the piston but you will still need to replace them in the 100 pass and 7-10k mile range
Old Jan 7, 2004 | 11:30 AM
Windage is a big deal with the older Chevy's, so knife edging does help them.
Old Jan 7, 2004 | 12:12 PM
DynamicZ28's Avatar
these days you can get 250 passes out of a set of aluminum rods..back in the day 100 passes was pretty normal, but you can get a lot more passes. I am building a full race motor so maitenance isn't an issue.
Old Jan 7, 2004 | 12:44 PM
Cstraub's Avatar
If you want an aluminum rod that has the life expectancy of a steel rod you can PM me. A 6.125" long rod is around 430gms. The technology is patented and 2 of the big three are looking at it along with Cummins. Cycle testing was done at the Dept of Energy in Oakridge, TN.
Cstraub
Old Jan 7, 2004 | 01:08 PM
If you want a good aluminum rod, I would say to you....use GRP. I have always used their rods and have had no problems. They are very friendly to deal with and seem to always deliver on time.
Chris
