cheatr v3 track results
Old Apr 14, 2010 | 11:16 PM
b4c346's Avatar
Default cheatr v3 track results
whoever may be intrested in a stock motor-exhaust camshaft.my car has 60,000 miles,3400 stall, m.t. drag radial's and 3.23 gears.100 r.w. nitrous dynotune wet kit.went to the track tonight ,and went 12.35 on motor.did a nitrous pass with a 1.6 activation delay,due to the track was loose and went 11.60.car pulled great to 6500 r.p.m.just posting this for someone looking for a stock cam idle,and stock exhaust,running nitrous.
Old Apr 14, 2010 | 11:37 PM
c5formula's Avatar
i would really be interest in a idle video of this car greatly... also what mph did it run on motor and on nitrous? what were the 60 foot times?
oh did i already say that i would really like to see an idle video of your car?
do you have any exhaust work at all?
Old Apr 14, 2010 | 11:50 PM
b4c346's Avatar
the 60 ft. was 1.79 and 110 m.p.h. on the 12.35 run.the 60 f.t on the bottle was 1.83 at 118 m.p.h . with a 1.6 activation deday .i went 11.61.no exhaust work at all.i will try to get you an exhaust video .
Old Apr 15, 2010 | 06:02 AM
PRE-Z06's Avatar
If ya don't mind, I'll add I run pretty much the same cam(custom XFI 218/230 .605/.604 116+2) with PRC stage2.5 heads in my 99FRC and it has been a best of 11.0@124 1.54-60' all motor
Old Apr 15, 2010 | 07:18 AM
logicsound's Avatar
did you have to replace/upgrade the springs? also is this cam good with LTs?
Old Apr 15, 2010 | 10:54 AM
b4c346's Avatar
yes,i used comp 918 springs and hardened pushrods.the cam will work with headers.i picked this cam because it's made to work with exhaust manifolds and nitrous,and the car is still quiet.
Old Apr 15, 2010 | 07:19 PM
JOSH13's Avatar
Nice results . I'd like to hear a sound clip . I'm wondering how it would sound with LTs
Old Apr 16, 2010 | 02:08 AM
c5formula's Avatar
was that with any exhaust work done? you have any idle videos?
Old Apr 16, 2010 | 05:15 AM
PRE-Z06's Avatar
I run kooks 1.75" headers, hi-flow cats and stock z06 titanium exhaust...search "vegaman72" on youtube
Old Apr 16, 2010 | 05:34 AM
Ruckus46Gt's Avatar
what's the da like where you run. I ran basically the same number .03 on motor off (same 60'), but da was only around low 2,000's. My mods are full exhaust and a 3k stall only
Old Apr 16, 2010 | 10:54 AM
b4c346's Avatar
there is a sound clip of my car i put in yesterday under(cheatr v3 sound clip)the only thing i did to the exhaust was replaced the stock muffler with a magnflow.stock manifold's,cats and flat y-pipe is still on thecar.
Old Apr 16, 2010 | 03:34 PM
redracer1's Avatar
I'm A4 also.....so the 3400 stall worked well for ya? looking at the TR V3 & AFR 205's and the stall is the last piece of the puzzle.
Old Apr 16, 2010 | 05:25 PM
b4c346's Avatar
yes,the stall works with my combo running nitrous.if your not going to run nitrous,i beleive you can go to a looser stall.talk to circle d or one of the other sponsors in the transmission section.
