Home 241 head Porting
Your upper-lift intake flow gain gives me hope.
Thank you for sharing.
Where the heads you used as an example a set you actually had on hand to look at, or just pictures? If its pics would you mind sending me them?
https://ls1tech.com/forums/generatio...d-heads-2.html
My thing is this: a CnC program already takes a proven port shape and cuts it out of your ports, which is better than what i can do even if i'm careful, and then the valve cut plays a large role in flow, and i can't do this myself. i would spend tons of time porting and making sure everything matched, only to pay money to have the head machined anyway, to still have something that is not as good as your run of the mill CnC job.
So, i say screw it. Unless you're dying for a DYI project, send them in. It would be a cool project to post about, but most people want results. Then you know what you're getting for sure, and aren't taking a ton of time out to do it. It's bad enough taking the time out to swap heads/cam/lifters/oil pump/timming system etc etc etc...
So for the ultimate, get the CNC job done. For GOOD gains, clean up the bowl/throat area yourself.
