Need Torque Specs for these Two Oil Pan Bolts...
I need the torque specs for the two very last oil pan bolts. They are the ones that are the closest to the ground, pretty much right where the tranny butts up with the block. They have 10mm heads, and seem kinda loose. I think the threads might be stripped. Thanks!
I NEVER EVER EVER EVER torque those......I snaped one the first time I removed the oil pan and had to play "chace the broken bolt out of the block".
Now I just take a 3/8 ratchet and snug them lightly. There are so many other good bolts on the oil pan (all the 8mm x 1.25s around the edge and the two big 10mm X 1.5s from the bell housing) that besides keeping the holes clean (keep dirt out), they don't really even need to be there.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
