cam specs
Old May 4, 2010 | 08:25 AM
TermnEatr's Avatar
Default cam specs
how would a 239/254 .605/.612 112 lsa cam sound don't really know anything about cam numbers.
Old May 4, 2010 | 09:11 AM
Preston129's Avatar
Loud; I'm sure it has some decent overlap to it. If you knew the advertised duration numbers we could see how much.
Old May 4, 2010 | 09:43 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
It has 22.5º of overlap @.050". That's quite a bit and will definitely have a tough lope to it at idle!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old May 4, 2010 | 10:22 AM
02*C5's Avatar
what is that cam going into it sounds like its gonna be a beast.
Old May 5, 2010 | 08:41 AM
TermnEatr's Avatar
a forged 370 on a 300 shot
Old May 5, 2010 | 10:27 AM
Engine_HP's Avatar
NOS and too much overlap dosent go together.
Old May 5, 2010 | 10:41 AM
Preston129's Avatar
Agree with the comment about limiting overlap above in theory, but here's where my understanding of N2O cams gets vague; the way I understand it, you want an early EVO event to let the higher than normal cylinder pressure escape, but I also understand that since you're chemically creating atmosphere, you can have a later IVO event and still maximize cylinder filling. So if the intake valve opens late, and the exhaust valve opens early, how would you limit overlap?
Old May 5, 2010 | 10:54 AM
SOMbitch's Avatar
[QUOTE=Preston129;13286197]Agree with the comment about limiting overlap above in theory, but here's where my understanding of N2O cams gets vague; the way I understand it, you want an early EVO event to let the higher than normal cylinder pressure escape, but I also understand that since you're chemically creating atmosphere, you can have a later IVO event and still maximize cylinder filling. So if the intake valve opens late, and the exhaust valve opens early, how would you limit overlap?[/QUOTE]
Wider LSA....
EDIT: IMO you need to get a custom specced for your setup and that big of a shot and I bet it won't be on a 112....
Old May 5, 2010 | 02:34 PM
TermnEatr's Avatar
what would happen if I ran the nitrous with that cam?
Old May 5, 2010 | 02:44 PM
SOMbitch's Avatar
Nothing bad but you can prolly tweak the specs a little and pick up a few ponies....
Old May 5, 2010 | 02:59 PM
TermnEatr's Avatar
thanks for the help hope to have it running soon
Old May 5, 2010 | 07:25 PM
SOMbitch's Avatar
Keep us posted..... Should be a handful with a 300 shot
