El Torro cam specs
I got my El Torro dyno tuned today. 404hp/368tq I was hoping for at least 400 hp but I also hoped for a little more torque. I guess it's not bad for only running LS6 intake, stock 243 heads milled .028, pacesetters with catted y pipe with 3.90 gears and a six speed. The tuner didn't care for the cam. He thought it would make more power with its specs. He did say if you didn't know what the dyno numbers were you would swear it makes more power than what it does.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
LSX Mechanic
The El Torro hype needs to end. It's not a very impressive cam, and not of the cars I've installed it in make an amount of power worth even posting on the internet. It makes a decent TQ curve, but that's about it.
And FWIW, this is no discredit to Predator. He is a knowledgeable guy and knows his valvetrain stuff well. I'm just not a fan of the cam. It's never impressed me, nor has the driveability.
#32
https://ls1tech.com/forums/11455510-post1.html
Btw where the hell is Predator?
#33
I think this is the cam he is talking about 230/228 .612/.588 110-1 LSA This was before the El torro.
Last time Pred disappeared for a while his job had taken him to the desert with no internet access...... hope the same this time...
#35
I have the el-torro cam and my car runs great and it's not even fully tuned!!! I did mine as a 230/232 because i knew i would be putting better heads on at some point in time. The extra 2 deg of duration on the exhaust would help with removing the exhaust gases. My car has just been tuned on the street by me and a buddy and has ran a best so far of 11.84 at 114.5. My buddy who did the tuning has only tuned his car which is just a bolt on car so by no means did either one of us know what we were doing. It still has some little bugs to work out but i am very happy with the cam and beat up on a guy with a MS4 cam also.
#36
That's a good time 11.84. I could handle getting into the high 11's. I almost want to have it dynoed again. I pulled the 80 series flowmaster off last night and drove it with open exhaust. Holy crap what a difference. It lit the tires up all through first and got sideways when I went to second. It never broke them loose in second like that. It sounds sweet dumping over the back axle. I need a different muffler. I'm thinking of putting an SLP loudmouth res back there and see what it sounds like.
