which cam is better to get?
Old May 8, 2010 | 04:14 AM
kingd_202's Avatar
Default which cam is better to get?
Im wanting to keep my car a sleeper! I was wondering which cam to get the torquer v2 or the 224r cam? Or is there any other cams that will give me a stock sleeper like idle? I need info asap! Im ordering my cam in the next couple weeks! Thanks guys
and my car is a ls1 t/a
Old May 8, 2010 | 04:52 AM
jc98ss's Avatar
i think thunder racing has some cam/head packages that would fill that role....scroll down on this link and check out the cheater cams
http://www.thunderracing.com/catalog...&vid=3&pcid=51
Old May 8, 2010 | 07:43 AM
RedRocketZ28's Avatar
Neither one of the cams you chose would be anything near a "sleeper" like idle. Look at the link posted above or get something custom ground to tailor your needs/wants.
Old May 8, 2010 | 08:36 AM
Longshot LCMS's Avatar
I've got the Torquer 2 and it lopes HARD... even with a 114 LSA you aren't going to get that car to have a stock like idle.
Old May 8, 2010 | 01:02 PM
guns77's Avatar
Check out Thunder racings Cheater cams . Or go with a custom cam.
Old May 8, 2010 | 01:21 PM
ssinister550's Avatar
any cam with mid 230's duration or less and a 115 or wider lobe separation will idle smooth similar to stock. the wider the LSA, the less valve overlap, the smoother, less choppy/lopey (more stock like) idle you will see... hope that helps!
Old May 9, 2010 | 01:43 AM
LilJayV10's Avatar
I would talk to Pat G about the EPS cams. A guy put down 430 to the tires in a LS6 w/ long tubes and a good y pipe and had a stock idle.
Old May 9, 2010 | 11:30 AM
Paint_It_Black's Avatar
EPS cam
-4 deg overlap
