Comparing stock cams (low end vs high end)
I'm in a racing class that requires stock internals. So comparing the 98-00 cam vs the 01-02 with all else equal (LS6 intake, headers, no AIR or EGR, etc.) which cam is better down low? I'm assuming the 98-00 cam is better up top... correct?
Stock LS1 cam '98-00:
202/210 intake/exhaust degrees duration
.496/.496 inches lift
116 LSA
Stock LS1 cam '01-02:
198/197 intake/exhaust degrees duration
.478/.478 inches lift
115 LSA
116 LSA
115 LSA
Yes, the '01 and up cam is supposed to be better down low. I have personally never seen an '01 + motor with a pre '01 cam in it but I have heard the 202/210 cam will make about 5 more peak RWHP. It would be interesting to see if there would actually be any significant low end losses switching to the 202/210 from yours. My internally stock '99 made 300 RWFTLBS @ 2000 RPM with an LS1 intake and FLP LTs through cats, so the 202/210 is no slacker down low either.
Man get the LS6 cam or the GT3 LPE stealthy cam and no one have to know LOL. If u ask which one would i choose between the cam u listed i would go with the 98-00 cam. Im sure it will make more power down low and up top too.
that is what I heard as well... (do not know for sure), but when the 01-02s put the LS6 Intake on it they reduced the CAM to try to keep them somewhat even to the 98-00s, but still rated it at 5 more HP
116 LSA
115 LSA
116 LSA
115 LSA
I would run the 98-00 cam because the extra lift and duration are worth more than the 1 degree tightening of the LSA on the 01 cam to tune for no egr (NoX control) The gains in power on 01 was from LS6 intake, not cam spec changes. It would be great if you could run 02 LS6 cam since it has GM part#
Check out your rules closely!
In case you missed it
those cam specs that you posted in your first post are wrong..i have the correct specs at work..but i know for a fact those specs are wrong..both cams are like 198/206..in that range and one has like a 120 LSA
here it is
To solve a discussion on LS-1.com about the stock 98 cam specs I took a couple of cams to Comp and got them profiled..here are the results
stock 98 trans am cam
duration@.050 198.86 intake 209.25 exhaust
lift .498 intake .497 exhaust
LSA 119.45
stock 02 trans am cam
duration@.050 196.37 intake 208.72 exhaust
lift .464 intake .479 exhaust
LSA 115.92
LSA 119.45
LSA 115.92
