6.0 install for '99 Camaro????
Old May 17, 2010 | 08:58 AM
dragracer5372's Avatar
Default 6.0 install for '99 Camaro????
i bought a '99 SS roller last year and after trying to decide what to put in it i have decided to go with a carbed 6.0....can anyone tell me any specifics i will need to know to install one.....oil pan, headers, etc. i was going to go with a BBC, but have decided this has to be easier to do with fitment, etc. and i do not want to do alot of butchering if i don't have too. if anyone has done one or know of someone that has, let me know what i will need to know before i get into this. Thanks in advance!!!!!
Old May 17, 2010 | 10:06 AM
rich5368's Avatar
Headers should be the same as usual. I am pretty sure the LS1 oilpan will work. Just curious as to why you're going carbed. 6.0l EFI can make gobs of power. To my knowledge the carb kits limited as far as tuning to whatever the MSD box will do as opposed to a guy that can tweak every last thing on a dyno.
Old May 17, 2010 | 10:28 AM
if i can find a complete 6.0 with fuel injection and computer then i probably would do that, but it seems to be i am finding there is always something missing and can't find a complete set up.....so i figured i would just go with a carb since i am more familiar with those. and it will either be a th350 or 400trans too. and i don't have anything to compare dimension-wise either since it was all gone when i bought the car, so i assume it might be a trial and error deal too with oil pan, headers, engine mounts, etc.
Old May 17, 2010 | 10:43 AM
blue99fbody's Avatar
y would it be trial and error? buy the parts for the car your putting it in. the motor is no different than the ls1 that cam out
Old May 17, 2010 | 10:47 AM
that is what i was wondering.....everything else i have for drag cars or muscle cars are older so i wasn't sure on this car. are there any years that are better to look for in a 6.0 than others? Thanks!
Old May 17, 2010 | 01:32 PM
maybe someone can tell me if this is a decent price.......was offered to buy a complete 2001 6.0 with injection, starter, alternator, PCM, and wiring with 150,000 miles, 190# compression, 60# oil pressure for $700......i just basically need to know if there are certain years to stay away from or which years are better than the other! Thanks!
Old May 17, 2010 | 01:42 PM
rich5368's Avatar
All the junkyards here in the Denver area are asking between $900-$1500 for complete intake to oilpan 6.0s out of yukons and such. You'll have to change out the intake and oilpan to F-body stuff as the truck ones won't fit. Other than that you can throw it right in and have the trans stuff for the th400 all churched up when you do your tune. I would certainly pay the guy $700 bucks and throw some forged rods and pistons in the bottom with some heads, headers, intake, cam and tune and then have a damn stout motor.
Old May 17, 2010 | 01:45 PM
rich5368's Avatar
Don't forget to find out if it's an LQ4 or LQ9. Escalades, sierra Denalis and the some of the SS trucks had the LQ9 which has higher compression and 25 more hp.
Old May 17, 2010 | 02:12 PM
Thanks!!!! is there an L92 too or is that something all together different? so basically all years of the 6.0's are pretty decent, just some models of them are alittle stouter than others......learning more and more everyday on here. Thanks again!
Old May 17, 2010 | 02:18 PM
rich5368's Avatar
L92 is the newer 6.2 that the new trucks have.
Old May 17, 2010 | 02:19 PM
rich5368's Avatar
Only difference between the LQ4 and LQ9 is the LQ9 has flat top pistons that raises the CR to 10:1
Old May 17, 2010 | 02:34 PM
it looks like i will be looking for an LQ9! Thanks again!
Old May 17, 2010 | 02:51 PM
that must have been why it was a little cheaper than most of the others, i called him back and it is a LQ4 with VIN code U......and i am assuming this is a dish piston with 8.5-9.0 to 1? at least now i am going into this with a little more knowledge than i had this morning!!!! Thanks!
Old May 17, 2010 | 04:40 PM
rich5368's Avatar
9.4:1 for the LQ4. They are cheaper and all it takes is a set of pistons or some smaller chamber heads or for that matter both and you're kickin 11:1.
