Need a cam
A couple good options.... Look in the for sale section for a good set of used heads. You can save up to 50% doing this and find a great set of heads for around $700. Or, you can do the same thing with a cam, pushrods etc. Just because you get something used doesn't mean you will make any less power.
There are lots of people on this site that change head and cam combos fairly frequently. That leaves a lot of good parts for sale cheap.
If you go new on anything talk to Texas Speed. I have bought lots of parts from them and their customer service is GREAT. Even if you go used you will still need seals, gaskets etc so talk to Texas Speed.
Good Luck.
get a cam kit (cam, pushrods, springs)
if possible upgrade your oil pump....150 bucks new...
all necessary gaskets
get a converter
tune
also dont forget some of the small thinks, oil pressure sending unit, any worn gaskets, waterpump gaskets
