Which Cam to Buy
Old May 31, 2010 | 07:18 PM
Auto's Avatar
Default Which Cam to Buy
I am going to put a cam in 01 SS M6. My car has pipes and a air lid. I want to put a cam in it i was thinking about the Torquer V3. Any comments or suggestions. Thanks
Old May 31, 2010 | 07:26 PM
brian_rs/ss's Avatar
the v3 is pretty big for stock heads IMO. i would go with something more under the curve. custom is always best but i went with a 224r. the 228r and tq v2 are also real good choices for off the shelf.
Old May 31, 2010 | 10:03 PM
94lt105's Avatar
Depends on how big you wanna go.. I went with the TSP Tsunami, yes it's a big cam, but I figure go big or go home! I would rec. either the V2 or V3 or possibly the 224 or 228r! Good luck with your choice n let us know what u choose to do!
Vince
Old May 31, 2010 | 11:26 PM
180ls1's Avatar
do you have headers at least? If you do that is a pretty good cam i would not want to go much bigger unless you want to get gears also.
Old Jun 1, 2010 | 06:43 AM
Auto's Avatar
I have LPP long tubes and mid pipe. Borla Cat back. Factory LS6 Intake manifold. And I was going to go with a set of gears as well.
Old Jun 1, 2010 | 12:41 PM
if you are stock heads/intake then stay away from anything that has v3 or stg 3 in the name....
Old Jun 1, 2010 | 01:47 PM
Cape T/A's Avatar
if you get to big of a cam you better plan on buying some injectors, valve springs, pushrods, retainers, and locks. It also wouldn't hurt to do a timing chain.
Old Jun 1, 2010 | 01:57 PM
ReApEr75's Avatar
And Lifters depending on how many miles are on his car (100k+). (Btw, Sig. is awsome!)
To the OP if your buying a Cam Kit, it should include everything you need, except timing chain / oil pump. But "best" cam would be custom grind.
Old Jun 1, 2010 | 02:02 PM
Cape T/A's Avatar
Thanks! Oh yah, I forgot about the lifters. Thats a given to me, I always replace stock or dated ones.
Old Jun 1, 2010 | 02:10 PM
ReApEr75's Avatar
Np.
OP if you get lifters I would recommend LS7 lifters. There not pricey and there good for what your looking to do. That is IF you buy them. Good Luck!
Old Jun 1, 2010 | 04:09 PM
180ls1's Avatar
here is the specs on the cam
TSP Torquer V3-231/234 .643"/.598" 111 LSA
that is not huge and it will work well with stock heads
Old Jun 1, 2010 | 04:47 PM
Cape T/A's Avatar
wont you have to fly cut the pistons with a .643 lift?
Old Jun 1, 2010 | 04:55 PM
vetteboy99's Avatar
228r or G5X4 or X3 cam
Old Jun 1, 2010 | 05:06 PM
TooLateVTEC's Avatar
How about telling us how much power you wanna make, is this a DD, what are the plans for the car in the future, have you ever had a cammed car before, have you done any research at all, etc. ?
I feel like I need to save that in a Wordpad document for all these people that start threads like "what cam should I get", so I can just copy and paste the **** in every one.
Its like going to the bar and asking " whats the best drink you got ? " Everyones answers are going to be different.
Old Jun 1, 2010 | 08:39 PM
Auto's Avatar
The car is not my DD. It has 45k miles on it. I want agressive street car that i can have some fun at the track with. I also take the car a couple long drives each year about 300 miles from point A to B on the longer trips. I would like to try to break 11's with the car. When i called Texas speed they said if i go with the 111 lobe separation i will not have to fly cut the pistons.
Old Jun 1, 2010 | 09:21 PM
garygnu's Avatar
with a good clutch and suspension parts a 228r will get you in the 11s.
Old Jun 1, 2010 | 09:23 PM
^hell not even that much if he is rockin the driver mod.
Old Jun 1, 2010 | 09:34 PM
LS12Fast4U's Avatar
Get the T-Rex cam!!! Kidding, the 228R from what i hear is an awesome cam. Everyone has always said good things about it. I kind of wish i would have gone with that cam now but o well. Im running the Cheater V3 cam now and its a nice cam but i feel like i could have went bigger without any loss in drivability.
The only reason i went cheater is because no one around here can tune for **** and im not driving a car un tuned.
So if i can give any great advice it is make sure you know who you will have tune it and make sure they know what they are doing.
Old Jun 1, 2010 | 10:05 PM
ive got a friend with the same set up as me but a 228r and slightly ported heads and he is making 412 rwhp. same driveability as my 224r.
Old Jun 1, 2010 | 10:12 PM
desertLS1's Avatar
Get a VRX4 from vengeance racing and don't look back.
