Got my first Ls1 build started
Old Jun 6, 2010 | 10:35 AM
  #61
garygnu's Avatar
if you already have a ls1 block do the 383.if you don't have a block get a ls2 block and build a 402,and get some l92 heads for TSP.
Old Jun 6, 2010 | 06:41 PM
  #62
blk/slvr02ss's Avatar
Texas Speed has a lot of nice choices so go to there website or give them a call and they can point u in the right direction.Also there is a section on that stuff on our website that says how to make 500rwhp.
Old Jun 6, 2010 | 06:55 PM
  #63
SWEET98SS's Avatar
IF you look under streetsweeper cam, there are a couple guys with this cam and either ETP heads or performance induction heads that made between 480-515 rwhp. I have this cam and love it so far. Fast enough for me with 405 rwhp.
Old Jun 7, 2010 | 11:53 AM
  #64
willis b otch's Avatar
https://ls1tech.com/forums/generatio...-stage-ii.html
Old Jun 7, 2010 | 12:19 PM
  #65
djsanchez2's Avatar
Stock displacement? AFR 205's
Old Jun 7, 2010 | 12:51 PM
  #66
Paint_It_Black's Avatar
For a 3.9 bore:
T4P Heads by Bauer racing Engines
Meaux Racing Heads
Performance Inductions
Pro-Filer Heads
Trick Flow
Air Flow Research
Old Jun 7, 2010 | 01:35 PM
  #67
Defined1983's Avatar
Get an LSX block and build it up.
Old Jun 7, 2010 | 01:53 PM
  #68
00T/AWS6's Avatar
is it a street car?? DD?? Weekend Warrior?? Drag strip only car?? What kind of trans, etc. I mean you can get 500 h/c but then add rear end, trans work, and your powertrain will eat it if your a drag car.
I think it was TR that had their stroker cam in a 383 that made like 540 or something crazy like that haha. It can definitly be done with the right amount of money invested and the right parts used.
Old Jun 7, 2010 | 11:58 PM
  #69
dnkynrbk's Avatar
Man I would read throught the stickies above. I would just get a good head cam combo. and find a good tunner.
There is so many factors. Do you have a built trans? a stock one will not hold the H.P.
And a 500 hp ls1 motor is alot unless you have a great set of heads and cam. Then the right trans gear combo.
Old Jun 8, 2010 | 10:46 PM
  #70
Jeff Smith's Avatar
Subscribing>>>>
Old Jun 8, 2010 | 10:59 PM
  #71
izzman55's Avatar
iv decided to go boost, to achieve this goal of 500 it would be best to do boost and more potential that way. im thinking some 6L truck heads, i may need a new crank i gota see if its fixable, had a spun rod bearing
budget is 3-4k
Old Jun 8, 2010 | 11:04 PM
  #72
budget is 3-4k
your cheapest FI route is going to be a remote mount (rear mount) turbo and a cam. Some 6.0 heads if you get them cheap.
Old Jun 9, 2010 | 12:35 AM
  #73
lemons12's Avatar
Originally Posted by Jeff Smith
Subscribing>>>>
It was dead man, come on...
Old Jun 13, 2010 | 04:19 PM
  #74
2001AntiVenom's Avatar
408 is around the same price if not cheaper that makes more power
Old Jun 13, 2010 | 04:53 PM
  #75
smok'nZ's Avatar
MASS seller approved
sell the ls1 and build a 370 or 408
Old Jun 15, 2010 | 06:40 PM
  #76
madden's Avatar
so i got an ls1 and i want to stroke it to a 383. i want to do n.a and large cam nice heads but want to maintain a budget build. can i make a motor now to 500rwhp with a reasonable cheap price tag.
There is really no 383 or 408 stroker combo that is "reasonably cheap" and makes 500 RWHP. You are better off with a stock bottom end LS1 with awesome heads, custom cam, roller rockers, 1 7/8" headers, and fast 92/92 (or 102/102). A less than stellar stroker combo will not outperform this option.
If you really want to stroke it. Don't spare any expense with heads and intake or you might regret it.
I had the same thing in mind that you do and in the end I went with very nice components as i didn't want to have an under-achieving stroker that would get smacked by equal weight heads/cam ls1 cars.
Old Jun 16, 2010 | 01:22 PM
  #77
smok'nZ's Avatar
dont waste money on that ls1 thats like polishing a turd once you spend a bunch of money on H/C/I the stock bottom end could give at any moment
