??? LS1 cam or LS6 cam ???
and more from 6k+.im not really a big fan of rockers seeing as how it limits you on future cam choices and you can buy a cam for cheaper and make more power but go with the rockers if you so choose.
if your talking about which cam would you use for the rockers the ls6 will gain you more power then an ls1 with the same rockers. if you use the ls6 cam with the 1.8's make sure you have a spring good for .600 lift as i think the slp springs in the kit are only good for stock ls6 lift.
Put some Comp 918's if you're gonna do the Ls6 Cam + 1.8 Rockers.
You will probably coil bind with that combo.
