6.0????
Old Jun 11, 2010 | 10:14 AM
Turnin20s's Avatar
Default 6.0????
Ok I found a 6.0 locally for $550 complete out of an 03 truck that has about 90k miles. The guy wants $550 if I pull it and I get the wiring harness and the computer as well as acesseries. I'm having a hard time deciding if I should get it and just store it until I'm ready for it, or buy some other parts with the money I'd spend on the motor.
Basically is the deal on the motor too good to pass up on? Or could I wait and find the same deal?
Old Jun 11, 2010 | 10:26 AM
Mac 2002 SS's Avatar
get'er azz !!
Old Jun 11, 2010 | 10:27 AM
rich5368's Avatar
Personally I'd jump on it. Junkyards here in Wy and northern CO are selling LQ4s for $1200 or more.
Old Jun 11, 2010 | 10:53 AM
Turnin20s's Avatar
Thats what I thought. I browsed around on the net and most of everything was $1200+
It will be a year or 2 before I would put it to use is the only thing, but for the price I'm having a hard time passing it up and I figured I could pull off the heads and intake and sell them for what I would have in the motor making it basically free.
Oh the mind is wondering haha, thanks guys
Old Jun 11, 2010 | 11:14 PM
99Zeeeeeeeeee28's Avatar
That's a great deal. I bought my '05 LQ9 for $1000 and it has 70k on it. Pick that motor up, sell the heads and intake and do the L92/LS3 top end setup.
Old Jun 11, 2010 | 11:20 PM
javier1730's Avatar
i found one locally also out of an 06 with less than 30k for $600 with accessories and heads...but im still debating wether to get it or not.....would it be too much work to put on a camaro?
Old Jun 12, 2010 | 08:57 AM
beedo's Avatar
I bought a LQ9 intake to oil pan with harness, pcm acc, and 42k on it for 1200, they can be found for a good price if you look around some. Good luck
Old Jun 12, 2010 | 09:45 AM
odarabla's Avatar
Wow really? When I was thinking about building a 6.0 iron block I bought the short block from a local junk yard for $300.00. I gave the block to a buddy of mine and I still have the crank.
Old Jun 12, 2010 | 09:49 AM
87silverbullet's Avatar
^^^^Do you think you would want to sell the crank?
Old Jun 12, 2010 | 10:17 AM
malibutwins's Avatar
I have a crank for sale 50 + shipping
Old Jun 12, 2010 | 07:10 PM
camarof41_383's Avatar
I looked for months and never found a deal that good. 6.0's are hard to find around here and they want a fortune for the low mileage ones.
Old Jun 13, 2010 | 04:46 PM
Turnin20s's Avatar
It is just a bad time for me as far as cash goes. I put my shotgun on a local message board and if it sells I'm picking up the motor.
Whats the compression ratio on a stock 6.0? And what are you guys putting down rear wheel power wise on the stock short block? I plan on keeping the bottom end stock and just doing heads, cam, and intake and supporting mods, if I end up with it
Old Jun 13, 2010 | 11:50 PM
ZERO's Avatar
Well since its an 03 shortblock my guess its an lq4 and if i am correct lq4's have a 9.4:1 compression ratio due to their dished piston.
I could be wrong tho.
Old Jun 14, 2010 | 12:19 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Too bad you don't get the heads with it.
Old Jun 14, 2010 | 05:10 PM
Turnin20s's Avatar
I do get the heads with it and the intake, the pcm, the maf, and the wiring harness.
9.5:1 isn't too terrible, but I would rather have closer to 10.5:1 or 11:1
Old Jun 14, 2010 | 08:36 PM
95wannabe's Avatar
where are you located??? $1200 + around here too
Old Jun 14, 2010 | 09:16 PM
2000TransAmWS6's Avatar
i think you have the right idea!
get it and sell the stuff off of it that you KNOW you won't need, and at worst you have $100-200 in it after you've sold the stuff. thats still great!
thats what i did with my 6.0 and it worked out great for me.
Old Jun 14, 2010 | 09:25 PM
Justus67's Avatar
BUY IT!!!!! I paid $1500 for my long block with 30K on it. You can pick up some LS2 pistons pretty cheap, you want those because they are the flat tops and will bump the compression up. Keep the 317 heads and mill them and that will bring the compression up even more, or sell them for some LS6 heads.
Old Jun 15, 2010 | 02:26 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Oh wow! I thought you were talking shortblock.
Old Jun 15, 2010 | 04:05 AM
odarabla's Avatar
I still have it but I promissed it to another friend of mine.
