243 setup...HELP!
I'm going to be doing a H/C/I swap on an '01 LS1. I've got a set of stock 243s, a FAST 90/PTM 90mm TB, and I plan on having Patrick G spec a cam. I've decided to send the 243s to TEA for porting. I would like to get ~450rwhp and at least 400rwtq from the whole setup, but the catch is I want the cam to be stealthy. I want it to have a near-stock idle. I'm not dead set on the 450rwhp number - if it's 10-15 HP less, I'll be happy.
That being said, setting up the 243s correctly will play a big role in achieving my goals, correct? I'll be keeping the stock valves, for better valvetrain stability. How much should the heads be milled, if at all? Should I just go with a thinner head gasket? What else can I do to "optimize" a set of 243s?
FYI, here are my supporting mods:
SLP lid/smooth bellows, SLP CAI
Pacesetter LTs, ORY, Borlamouth
I'll be getting an underdrive pulley and possibly an electric water pump, as well.
If you are already putting down the numbers in your sig, then I think you will be pretty close to your goals. That isnt bad at all for just some bolt ons.
One more question - I know flow #'s aren't everything when it comes to cylinder heads, but TEA's exhaust flow #'s are way ahead of other comparable companies' heads (meaning "Stage 1" or similar heads). Will this translate to a significant advantage, assuming the combustion chambers and runners are equal to a comparable cylinder head with less exhaust flow?
Before I forget I don't mind fly cutting but to me is fo last resort. If you can find a cam lets say smaller that gives you close performance to a bigger cam and it will take that option away then I'd go with the said cam.
