Mmm Cam/lifter carnage omnomnomnom
I was in pretty good spirits about the whole thing...but Fedor just suffered his first real loss. FML I should've stayed in bed.
Futural had a bad run of the f13 cams a few years back and it was actually the material in the cam. It could be a few different things though. It could be the lifters failing also.
This happened to my car after 1750 miles, the shop wouldn't stand behind there work it cost me $2,300. then when I got the car back the rear main seal was leaking????????? they wouldn't stand behind that ether, I could on and on about this shop.
I'm going with the use of synthetic oil. Yeah, I know the first thing all of you are gonna say is that many LSx cars come with synthetic from the factory. Thing is since I have worked for THE cam manufacture, it's not an uncommon problem. The oil is too slick and the lifter doesn't roll, it starts to slide and creates excessive heat...... nuff said
#33
#37
I am sure that the damage has been carried completely around the affected lobes and therefore you could not get a good reading from it.
The other lobes would probably check out fine since they are ok any way.
Just my .02.
Also, I have noticed the same type of damage on some the higher mileage cars that I have done heads and cam swaps on.
These cars were stock and were running a syn. oil. (I know because I always have the customers bring me the oil)
I don't think I have seen one running conventional or a syn blend hurt like that(but I am working off of memory here).
Once more.....just my .02 .......I'll go back to lurking now...........
#38
hardening does not come off,it is not a coating the metal get heat treated to harden it.maybe it was not harden properly.I believe valvevoline racing oil has the zinc in it still.could be lack of spring pressure,springs loose their strength after awhile.ask Jon Bauer he'll tell us what really happened.
