Balancer bolt walking out of crank!
i got an LME 408 built last year, NA motor nothing crazy, well oil pressure dropped while driving a week ago, i had replaced the oil pump and o ring in attempt to regain oil pressure with no such luck, and i noticed after a short drive that the balancer has a small peice cracked off of it and the bolt walked its way about a half turn out. The balancer bolt is brand new from the dealership, just wondering if the balancer can be to blame for this??? and i believe oil pressure gauge can possibly be off? Any ideas?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
i got an LME 408 built last year, NA motor nothing crazy, well oil pressure dropped while driving a week ago, i had replaced the oil pump and o ring in attempt to regain oil pressure with no such luck, and i noticed after a short drive that the balancer has a small peice cracked off of it and the bolt walked its way about a half turn out. The balancer bolt is brand new from the dealership, just wondering if the balancer can be to blame for this??? and i believe oil pressure gauge can possibly be off? Any ideas?![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
The way our balancers stay on is that the hole in the balancer itself is smaller than the crank snout by a few thousandths of an inch. The paperwork that came with my Powerbond recommended between .008-.012 press fit. I dont know if you have access to inside/outside mics to measure the crank and balancer?
This is why heating up the balancer before install really helps. Heating it up, will make the hole bigger, giving you more clearance to press it on.
The harmonic damper is held on by the interference fit (the numbers above need one more decimal place) and contact with the timing chain lower sprocket/oil drive. If your bolt is backing out your interference fit may be too small. Did you re-use the stock damper (pulley)?
Second, when installed did you rotate the full 140 degrees or use LS1howto.com?
well this weekend ill tackle the problem, im buying a new balancer and ill mic the od and id of the crank and balancer, im also buying an arp balancer bolt, hopefully this will fix thanks for all the replies
