what heads for MS4 cam?
thanks-curt
Call TSP though, they will be able to tell you which heads to go with for that cam if you're dead set on the MS4
We not only can set up the PRC 215's to clear the MS4, but we can now also do the 227's for even more power on a stock short-block!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
