LS1 Build
Old Aug 4, 2010 | 11:59 PM
kobraa's Avatar
Originally Posted by JohnnyBz28
Nick you should also get a new timing chain since everything is apart.
Did that already when I changed up the cam
Old Aug 5, 2010 | 09:44 PM
kobraa's Avatar
Alright so I got some motivational good news after the leak down test today. I cleaned the bores and put new rings on a couple pistons, torqued the head down again using the same MLS gasket and only got 13% leakage on both cylinders. I think I'm just gona start assembling the motor and do another leak down test when i have the long block assembled. Considering all the bores look and feel the same, I think the rest of the pistons should produce similar results.
Old Aug 6, 2010 | 03:48 AM
kobraa's Avatar
I figured since I have gone this far I might as well just strip to the bare block and see if anything else was damaged
Not looking so good...
Hot off the BBQ...
Then I spotted these...pretty sure confirmed I need a new block so if anyone has a bare block or even shortblock laying around please let me know. Gota love no oil pressure
I'm also still working on converting the interior color to black. This is what I finished so far
Old Aug 6, 2010 | 07:22 AM
crainholio's Avatar
The bearing shell and cracked block don't look like oil pressure issues, that's a botched crank install.
What clearances did you measure on the crank mains, and what brand torque wrench did you use for the main bolts?
Old Aug 6, 2010 | 09:16 AM
gearhead1186's Avatar
im with you on this one. if you walked up to me on the street and showed me those bearings I would say you have excessive crush, distorted crankcase or a bent crank. it seems very drastic for oil starvation but still possible. a typical bearing that was starved of oil will turn dark blue or black but in the extreme it could tear apart like yours did. can you post pictures of all the main bearings in order?
Old Aug 6, 2010 | 10:48 AM
printmanjackson's Avatar
why don't you just buy a shortblock, wouldn't it be cheaper?
Old Aug 6, 2010 | 12:32 PM
kobraa's Avatar
Yeah, I'm in the process of looking for one thats decently priced. There are not too many good deals out there at the moment though..
Old Aug 9, 2010 | 07:00 PM
kobraa's Avatar
I got pretty lucky and found a guy selling a block and crank ]20 minutes away from me. I have been doing nothing but cleaning the whole weekend. Here are some pics
After a little wash and attention...
Also got done with one door panel
Old Aug 9, 2010 | 07:13 PM
JohnnyBz28's Avatar
Looking good buddy. This time around please please measure everything twice You need your luck to change and this time it should run 100% without any issues!
Old Aug 9, 2010 | 07:56 PM
crainholio's Avatar
This time have whoever built your last one sit on a stool and watch.
Old Aug 11, 2010 | 08:17 AM
jevonniespapi's Avatar
If you dont mind my asking, how long did it take to drop the motor?
I have never seen anyone drop the motor from the bottom with a cherry picker like that!
Old Aug 11, 2010 | 05:22 PM
  #32
Red face
It's pretty easy. 3 subframe bolts on each side, 2 strut bolts on each side,hydraulic line and the front brake lines off the distribution block. I'd rather do that than wrestling with the bellhousing/tranny bolts.
Old Aug 11, 2010 | 11:37 PM
  #33
stoning_volcom's Avatar
sweet build man keep the updates and pics coming along. That crank is knarly man hope all goes well. and see what kinda numbers ull be putting down with out the resistence woot woot!
Old Aug 12, 2010 | 04:56 PM
  #34
kobraa's Avatar
If you know what you're doing it probably takes a full day to disconnect everything from the top and bottom and then drop it. Its not too hard, but i crap myself seeing the bumper above me in the air hoping the whole car doesn't come crashing down.
Old Aug 12, 2010 | 05:01 PM
  #35
kobraa's Avatar
Thanks, i definitely will. I just dropped the block off at SK Speed in Long Island to get hot tanked, honed, and also getting new cam bearings installed. Should be done in about a week
Old Aug 13, 2010 | 07:33 AM
  #36
adkunlimited's Avatar
looks good!
Old Aug 24, 2010 | 12:11 AM
  #37
kobraa's Avatar
Just picked up the block today from SK Speed...looks pretty good, can't wait to start assembly tomorrow. Here are some pics, enjoy
Old Aug 24, 2010 | 12:18 AM
  #38
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Nice man! Get that thing together!
Old Aug 24, 2010 | 01:53 AM
  #39
Squirts11's Avatar
If you don't mind, what did you pay for the block? Also, was it just the crank and block, or other components as well (pistons, rods, etc)?
Old Aug 24, 2010 | 02:22 AM
  #40
kobraa's Avatar
I paid 280 for the block and crank only
