questions about spring problems in 2002 C5 Z06
I'm new to the LS world so I have no experience with these engines. I have noticed a slight noise coming from the engine when the rmps go above 2,000. For example if I'm crusing in 3rd gear going down a side road for awhile, I hear "the noise". Wondering if this is related to the spring problem? not really a ticking noise maybe a fluttering noise? Hard to explain what I'm hearing. Any idea what could be causing this. Car is a 2 owner with 66K miles.
Second you don't want to ruin your LS6 valves because they are hard if not impossible to find now a days at least the stock ones and they are expensive a hell.
rockauto.com used to have them but i don't think they do any more and they are expensive for a set if you can find them.
If you are going to do a set of springs do these http://www.jegs.com/i/Comp%20Cams/24...0002/-1?CT=999.
good luck
Get new pushrods while your at it. Stock pushrods are fine for stock cars driven normally. Not so good for the occasional OverRev.
Call any of the Vendors here. I Like Thunder Racing personally. They'll let you know what you need to accomplish what you'd like.
I have no idea what the noise could even be... A video is unlikey to help either unless it's an obvious problem. Get a Mechanic or knowledgable friend to ride along and listen for when and whetre the noise is coming from. Some mechanics have a "Chassis Ear" which is basically a bunch of microphones that can be placed on the vehicle and a receiver that can switch between them. TRhis is a quick and efficient means of tracking down a noise.
It does kind of sound like a sewing machine. Not sure on the oil. I just got it almost 2 weeks ago from a dealership in TN. I plan to change my own oil but need to get some low profile ramps first.
