M6 car with MS3 cam...lacking power?
Old Aug 15, 2010 | 06:22 PM
180ls1's Avatar
Originally Posted by Magnet
You have a lot of things going against it.. you need to, seafoam the car then change the plugs, oil, fuel filter, then make sure your clutch fluid isn't black, then port your stock throttle body and make sure you have a good lid and ram-air setup, then put it on the dyno and get a good tune for street and strip use.
Things to check:
-make sure clutch isn't slipping
-make sure springs are adequate
-make sure throttle body is opening 100%
Last of all, MAKE SURE THE ASR IS OFF
good stuff right here
Old Aug 15, 2010 | 11:12 PM
Duffster's Avatar
Has anyone said Traction Control Switch?
Old Aug 15, 2010 | 11:33 PM
180ls1's Avatar
ya someone mentioned it
Old Aug 16, 2010 | 09:50 AM
stereotypicalv8guy's Avatar
I don't have the button for the traction control and the car will spin just fine if it's wet so I'm not so sure that's the problem. Shouldn't a light come on or something notifying me that it's engaged?
Old Aug 16, 2010 | 09:51 AM
Duffster's Avatar
"Low Trac" lets you know you're spinning...
Old Aug 16, 2010 | 11:03 AM
Magnet's Avatar
Your car could have come without it, you need to make sure though. If something weird was going on that could easily be your problem...
Old Aug 16, 2010 | 11:43 AM
thunderstruck507's Avatar
check for codes, compression check (look at plugs while they're out), inspect plug wires, you said it had to have a new pcm? is it retuned for the cam with the new pcm? was it tuned on a dyno, street, or did you just have someone give you a generic tune for that cam?
then hit a track or dyno (being a m6 dyno might be better) to find out what its doing and when its doing it
Old Aug 16, 2010 | 01:29 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I just reread the first post, and you said you got it retuned, did they mention anything about there being problems? Who did the retune? Did they use a wideband O2?
I still think it's funny to judge how much power you have based on how much or little you're spinning your tires. Go put 35psi in the rears and you'll smoke em all day long. No more power than before, but, well you get the point.
Old Aug 16, 2010 | 05:38 PM
dwnshft82's Avatar
my 99m6 used to be prity much the same setup and it cold not spin the tires inless i dumped the clutch but ran a 12.40 all day spinning looks cool but dosent do much good try going to the track you might find you arent as slow as you think
Old Aug 16, 2010 | 07:23 PM
getsum27's Avatar
dont be cheap about your valvesprings!!!!!!!
drop a valve and your gonna wish you had listened
im willing to bet thats part of your problem
gears is the rest of the problem
Old Aug 17, 2010 | 10:57 AM
No "low trac" light comes on so I don't think that is the issue. The new PCM was tuned with a wideband by a reputable tuner. It was also tuned on the street otherwise I would have some dyno numbers for ya'll. Also, I do run 35PSI in my tires and it still doesn't spin. But it's more than just not spinning...it feels slow.
I'll try to get a compression test done but my tester and all of my tools are back home in Florida so I'll be limited to whatever the base auto hobby shop has available for me...not sure if they have a compression tester or not.
Old Aug 30, 2010 | 02:55 PM
  #32
I figured I would give ya'll an example of why I feel like the car is down on power.
Old Aug 30, 2010 | 03:04 PM
  #33
UNDER PRESSURE MOD
Seems like you have 3.42 gears, that's all.
Old Aug 30, 2010 | 03:13 PM
  #34
camz28arro's Avatar
Get rid of the flowmaster exhaust or get a cutout, change those springs with a cam that big, and raise your redline to 6300-6400rpm. The stock 2001 rod bolts should be able to take that.
Should definately spin at 30mph with 3.42s
Old Aug 30, 2010 | 03:16 PM
  #35
rob69zombie's Avatar
No offense, but that is weaksauce. I hope you figure it out soon buddy.
Old Aug 30, 2010 | 03:17 PM
  #36
I plan to do all of that. Actually, I plan to go with aftermarket rod bolts and spin it to 7000. I just wanted some verification that I'm not crazy before I go spending money on ****.
Old Aug 30, 2010 | 03:20 PM
  #37
You're not crazy. My SS is stock with LT's and a spec 3 and if I throw it in 2nd @ 55 it'll throw the LOW TRAC light on and you can feel the rear of the car squirm. You'll get it figured out. It could be a lot in the tune wrong as well. Again, good luck.
Old Aug 30, 2010 | 03:28 PM
  #38
fccs's Avatar
Wow theres so much fail in this it's hard to list it all.. lol
-You have a big size ms3 cam yet you have the redline at 6000... set it at 6800 with that cam
-You have stock gearing, get some 4.10s with that cam def.
-You have springs that are pushing the damn limit with that cam and are KNOWN to have issues.
-Stock clutch should barely be able to handle the extra power, and since that cam doesn't really MAKE GOOD power till like 4k, your not going to spin the tires down low when your just getting into your powerband to begin with.
-It probably will feel slow below 4k because that cam is designed to make power up top.
-Not to mention you have the worst flowing catback exhaust made for these cars...
Sounds like the person before you just felt like saying he has a donkey dick cam but nothing setup right or parts that would go along with it to make it USEFULL. Kinda like having a 12inch dick that can't get hard.. lol
Old Aug 30, 2010 | 03:36 PM
  #39
WSsick's Avatar
Originally Posted by The Alchemist
If you are really concerned about being down on power, get it on a dyno and see what it puts down. Get someone with a programmer to log some data and see if you're tune is off or if you're getting knock.
Definitely the best answer. A good logging session should let you know where you're at.
Judging how much power you're making by the ability to spin the tires is internet math.
I can spin the tires in a Ford Focus, does it make 400whp+?
Old Aug 30, 2010 | 03:38 PM
  #40
fccs's Avatar
Not from a roll you can't. I'm sure he can spin the tires very easily if he just dumps the clutch, but I think hes trying to say from a roll it isnt spinning at all.
