M6 car with MS3 cam...lacking power?
I think even with stock gears, yours should definitely be pulling harder up top, but even my smaller cam is getting pulled to about 64-6500 which yours should be pulled to MINIMUM
You can see how mine rows through the gears:
). No way in hell it spins them just rolling on a dry road.Adjust the rev limiter to a higher rpm, which is where your cam shines. A set of heads and gears would really wake it up too.
http://www.youtube.com/watch?v=pYSB4u8txJc
Everyone is being sarcastic because he's trying to diagnose his car by how much or little he's spinning his tires. That's not data, that doesn't give us a clue of how much or little power he's making.
He had the car tuned, and if the tuner didn't mention anything about the car being hurt, then he needs to get it on a dyno to see what it makes power wise, or down a track to see what times it runs. Evaluating how much power he's making by how much he's spinning the tires is just rediculous. That's even worse that the butt-meter.
You car should have enough power to spin the tires. The first thing I noticed is you COMP 918 springs. I bet your floating valve. My buddy had those on his LT1 with a smaller cam then the MS3 and floated the valves, swapped to PAC springs and picked up 70WHP!!
Id say pick up some patroit Golds. My friends been running his for 4 years!
Good luck man!
I think its the springs...
Jay
Good luck man!
Jay
As for springs, what do ya'll recommend? I was looking at the Precision Race Component EHT .675" Spring Kit but the Patriot Golds are cheaper (checked into them per Jay's recommendation).
http://www.texas-speed.com/shop/item...=1013&catid=48
http://www.jegs.com/i/Patriot%20Perf...0002/-1?CT=999
Its a cheap kit and has everything u need including valve seals.
Jay
Hell... when I was bone stock I would chirp 2nd and 3rd.
All I was trying to stress is don't make a diagnosis on the health of a car based simply on a feeling or how much or little traction you're getting. Get it on a dyno and see what the torque curve looks like.
