Polluter cam? Good for hwy hammerin?
#33
http://www.youtube.com/watch?v=tlUIM...ext=1&index=49
#35
The only one with Violent in its description!!
Thunder Racing Custom Camshaft
T-ReX v.2 - 242/248 - .608/.612 - 110 lsa 3500-6700 RPM Power Band. Violent mid-range & high RPM power. Requires computer tuning, 4000 converter on autos, 4.30's or greater depending on transmission. Works very well with nitrous and proper tuning. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Due to the extreme nature of this camshaft, piston to valve clearance must be verified when using modified cylinder heads.
View Dyno Graph Track Proven Performance! $384.99 Buy Wish
#37
is the trex flat out a turd for normal street driving? im mean, dang...
if so, id think twards the polluter. and for me fly cutting is out of the question....
i will use the stock 241 heads.
