Money no object... Best rocker arm out there...
#41
Well If i cant get a roller rocker to do what i need it to.. then I might consider a stock rocker.. But as of now its of the table due to the valve guide wear.
#42
Why can't you get a roller rocker? Also, if you have a float issue have you removed and measure a valve spring to see if it still close to its design stiffness value? Have you considered new valve springs and the same rockers that you have now? Have you verified the geometry on your current rockers?
