Serious Issue, please help. No oil pressure...Sending unit or lifter?
Ok, the last couple of days, while the car would be warmed up, the oil pressure would randomly drop at some lights, down to about 20 at idle. When I would rev it up, pressure would go up, and then down the road some it would go back to normal. Well yesterday, a vacuum leak appeared, car is trying to idle around 1500, and there is NO oil pressure. I was thinking the Oil Pressure Sending Unit broke somehow, I bought a new one, but the connection and everything feels fine so I didn't take it off yet just incase that isn't the issue. If it is not the unit....Lifter went out? Valve train is also very loud, which is scaring me that it could be the latter. Help would be nice..thanks yall.
What oil are you using??
Also would like to add my car had almost 115,000 on it and I barely touched my oil sender and it broke in half.
Also when I replaced my factory oil pump the oil pump gear inside the pump was just flopping around in the oil pump housing.So you might want to replace the oil pump also if you have alot of miles on your car.
Replace the sending unit.. or verify with a mechanical gauge. If the valve is "noisy" it might be the latter, but a bad lifter isnt going to give you 0 oil pressure.. anything short of a bad oil pump isnt going to do that.
Ok, I'll replace the sending unit tomorrow or maybe after class. Next question...only time I have done that was when I had the manifold off. I can touch it, but can't see **** and cant tell how the electrical connector comes off. I am assuming I can swap it out without pulling the manifold right?
When the H/C was done, what pump was installed and what time frame was the work done?
Valve train has always been noisey, but its hard to tell if its "louder" since its idling at 1500, not 850. So its not quite easy to tell really. Pump is a ls2 pump I believe...don't remember, I did all this back in June 09. Valve train is FTI Toxic Cam Kit, PAC 921 springs. All work was done in one day.
Honestly... the internet mechanics are great..
Lets do less guessing and leave the answers too people who have a dam clue.
Step 1. Verify Oil pressure with a mechanical gauge. ( if you have oil pressure, replace sending unit )
Step 1. Alternative, Since you have already bought the sending unit, replace sending unit if you have oil pressure problem solved.
If you have increased valvetrain noise, it might be an oil pressure problem. But this doesnt mean you skip step 1.
If neither Step one, Or the Alt work... Come back for more advice and we can go from there.
You can use the side port on the drivers side of the block, or the port that the sender is in.
Location: Your girl's back door giving her the long stroke while you're at work
This is the adapter you need for a oil pressure gauge
http://autometer.carshopinc.com/prod...9ef7bf4ea10010
Just saw this now...been busy with other stuff, but thanks for the help!
This little piece, is that what I need to hook up the mechanical gauge into where the electric gauge is plugged into? So I can just pull the electric gauge, plug the mechanical in real quick, see whats up, then if its the sender, just replace?
