Could someone compare these two cams for my setup...
I have come across two cams that according to people with tuning experience say will pass.
The first is the CheaTR cam (219/230 117)
The second is a 224/228 114+4
Both with around .600 lift.
So what are the differences between the two...
Mileage
Idle smoothness
Power
Mileage---------don't know-------------don't know
Idle smoothness--- yes -------------- no
Power --------------about the same give or take 15
Have you considered a cam similiar to the CheaTR but with a 115lsa or tighter(better low end power)?
EPS has a couple of shelf grinds that would be good, 218/226 113lsa and a 222/226 113lsa. You also could go with a custom TSP cam with a 218(.605"xfi)/230(.604" XFI) 115lsa.
http://www.engpwrsys.com/index.php?a...od&productId=8
http://www.engpwrsys.com/index.php?a...od&productId=5
http://texas-speed.com/shop/item.asp...d=898&catid=44
Thanks for the opinions guys, they have been helpful and I welcome more.
!! try the CheaTR cam if you don't like it you can always change it and next time go with a custom cams that will meet your needs Last edited by 99Bluz28; Aug 28, 2010 at 03:36 PM.
!! try the CheaTR cam if you don't like it you can always change it and next time go with a custom cams that will meet your needsI'm definitely getting the QTP front cover to make it easier "in case..."
