why did it do this?
After 100 miles she lost oil pressure. so i take it apart and the 2,3,4 main bearings have made contact with the crank. 1,5 look ok.
i put a dial on the crank and all is good.
details-
347
stock crank forged rods, piston arp bolts throughout and a ysi supercharger 18# boost.
pics-
so the question is why did this happen?
30 weight oil
Easy break-ins are controversial, so I am not getting in to that, but my fresh 408 was/is getting the **** beat out of it every time it is up to temp. The few people I know outside of LS1tech that are car enthusiasts have all done this with success.
All the plugs looked good when i took them out.
well i might have found out why this happened. When i brought it in last time he said it would need to be lined honed, well when i talked to him today i found out that he didnt do it because i wanted my engine back as quickly as he could. so i believe this is on him.
Did anyone cut the filter open on the engine shortly after you warmed it up (maybe put a little time on it) and dropped the oil right away? My guess is you would have already seen bearing material in your filter pleats but Im purely speculating. Point is thats a lot of bearing damage for an engine with so little time on it indicating something was probably wrong almost immediately.
What was the clearance of the mains and why are you running such thick oil?
Are you running excessive clearance that its necessary?
If they tuned it and they built it hopefully they are willing to take care of you....
Good luck with the situation
And a note to others that have a new motor going in their car or perhaps on the dyno.....buy a filter cutter for $25 or so and cut that filter apart almost immediately to get early detection of any problems. It can save you money in the event you catch something like this early.
-Tony
