Mopar killed my ls1
https://ls1tech.com/forums/general-m...-your-car.html
And after doing this my SES light came up and my motro shakes like a epeleptic drunk man, throwing code p300
what can i do im really desperate already changed my plugs and wires for new ones and still doing this im really really mad at this stupid thread dam
Also when doing the MCCC no smoke at al came out in the process??
I can't believe no smoke showed up. Did you let it sit in the cylinders for a while? You know going through the brake booster is only going to get the back 4 cylinders.
no smoke at all not sure what i did wrong but this is the whole story
ok i followed the thread and it said to put this foam stuff through the pcv line on the intake so i did, as i did it at first i did it too fast so motor shocked fast and shut off, so i cranked it back up and it struggle a little but cranked and then continue to introduce the can until it run out and turn it off, let it sit for 3 hours crank it back up with no problems just the ses light flashing and then running really rough and lean, took out my 3 day old plugs and where white tiped, went to autozone told me white plugs meant running lean condition so i bought a new set of ac delco iridium plugs, they told me not to gap them so i just install them got new plug wires turn on the car shakes and throws ses light still with the code p300
FWIW, I have done this on several cars, SES lights, engine running rough, etc, is all normal, to an extent.
Most recently, on my old 346, I used a B12 kit and it took around 4-6 miles for the smoke, rough running condition, SES lights, to stop and the chemicals to evacuate the engine.
