GM head bolt question
through my FAST back on and went to tighten it down and all the bolts went in fine and then the last bolt wouldn't start. hmmm... pulled the intake off and the PO snapped a bolt in the head from his manifold (Now learn a shop did, not the PO himself; we are trying to work this out currently).
So now I need to pull the head so I can get the busted bolt out of the head as I don't forsee the manifold sealing without it. Duh
So since I have torqued the stock GM bolts once when I pull them out are they now garbage? Same with the MLS GM gasket I used?
an "Easy out" is a reverse fluted drill bit sort of. They make really small ones you can get at an auto parts store for a couple bucks.
one if you need an easy out your turning on center this helps on larger bolts from twisting the easyout and snapping a hardened part in a bolt you cant get out
also if you find you need to drill out the bolt all the way your leaving a nice centered hole to retap or install a new thread (timesert or helicoil)
Oh and center punch before you drill into broken bolt . No need to pull cylinder head you will be wasting your time and money if you do and no do not weld onto it the aluminum will melt first from the heat and you will have a bigger problem .
X2 on the center-punch before drilling. Easy outs don't work when they are grabbing the hole you're trying to remove the bolt from.
X2 on the not pulling the head either. Rag in ports (all of them) and tape over the rag. Don't forget them in there. Shop-vac everything before installing intake.
I even checked a stock head. All of them go right through. Again, see if you have access to a welder. Just make sure everything is covered up. I've done this to bigger bolts stuck in aluminum, you won't melt it. Just build up a bunch of small tack welds so that you have a "shaft" to weld a small nut to from the inside.
That, or the trick mentioned in the 2nd post.
