Simple Cam Swap goes BAD
Old Sep 13, 2010 | 11:50 AM
the_blue_rider84's Avatar
Talking Simple Cam Swap goes BAD
So I went down to the shop sat. morning to swap the cam and springs. I planned on firing it up that night. I was down to the part where I use the lifter tool to keep them from falling.
AND THEN.......
I stuck a magnet in the pushrod hole and it got stuck in the damn retainer. The bastard magnet broke off down in there.
So all day sat., half a day sunday, and now tonight and I should finally hear it run.
I will post up some pics of the aftermath of breaking a magnet later along with the startup video.
BE CAREFUL OR JUST DONT USE A MAGNET!!!!!!
Old Sep 13, 2010 | 12:20 PM
sscamaroburn02's Avatar
well at least you got it right. took alot more time but once you hear your car with new cam it will be worth it.
Old Sep 13, 2010 | 02:18 PM
Silvy6.0's Avatar
Damn man. I always just go to Wal-Mart and buy two 5/16" dowl rods. I think they are only like $.40 each. Cheap insurance and it's guaranteed!!!
Old Sep 13, 2010 | 02:20 PM
SSmoken's Avatar
same here. sorry to hear about the bad luck. you will forget about that once she fires up.
Old Sep 13, 2010 | 02:23 PM
STAGEUP's Avatar
This has worked for me about 20 million times. lol
Old Sep 13, 2010 | 02:27 PM
ae13291's Avatar
i had the same thing happen. i used the dowels and one of the lifters dident want to stay up so i stuck a magnet in there and then got a little worried that it wasent coming out so i yanked on it harder then i broke the magnet in there took all night to get it out, i ended up using that scissor looking tool the doctors use and i was able to get it out.
Old Sep 13, 2010 | 02:33 PM
WYATT318MOPAR's Avatar
So after almost giving completely up, you smoked a joint and then used the hemostats to pull the magnet from the engine. Classic...... Now lets hear it
Old Sep 13, 2010 | 02:53 PM
NVR_SPDS's Avatar
That sucks to hear! I used the rods like everyone else, and it worked great.. What cam went in?
Old Sep 13, 2010 | 04:07 PM
shiv15's Avatar
Sucks about the magnet!
Kind off topic but we tried using dowels in two different motors and they didn't look like they were doing anything. We shined a light down and it didn't seem like they'd stop a lifter falling.
Old Sep 13, 2010 | 04:16 PM
Damian's Avatar
LSX Mechanic
1999 called, they want their cam swap ideas back.
People need to quit using the magnets for this reason alone. I had this happen to me as well back in 2000, and that was the last time I ever used magnets.
Spin the cam in both directions abruptly to throw all the lifters in their retainers, slide 2 steel 5/16 rods in each hole, and pull the cam out.
Old Sep 13, 2010 | 05:05 PM
ss454327's Avatar
Ok so explain to me how I will be doing it since I have an LQ9 and have been told there are no holes to slide dowels into?
Old Sep 13, 2010 | 05:08 PM
mike c.'s Avatar
in seven cam swaps i have NEVER used magnets or a tool to hold up the lifters. No problems like you have.
Old Sep 13, 2010 | 06:04 PM
rooster18's Avatar
can someone post pics of the holes to slide the dowels in. i will be tearing into mine this weekend for a cam swap and was going to be using the magnet method but after reading this i am kinda sketchy. would rather go for the sure thing
Old Sep 13, 2010 | 06:16 PM
Josh18Fan's Avatar
These are the two holes, on either side of the elongated "bowtie" behind the cam retainer plate. Insert the dowel rods into those holes after spinning the cam fully in both directions to ensure that the lifters are up in their bores.
Old Sep 13, 2010 | 06:17 PM
Josh18Fan's Avatar
LQ9's have the holes as well. Look at the post above this one for details.
Old Sep 13, 2010 | 06:22 PM
Funkster's Avatar
Shitty, at least you got it though.
Old Sep 13, 2010 | 08:45 PM
99wssixm6's Avatar
Same here and I had to pull the passanger side head......I also will never use a magnet tool. The $50 in head bolts and gakets sucks but I was so pissed to pull a stock head off and put a stock head back on. My Fiance' ask what was wrong and I told her it was like having a miss-carriage - all that work and nothing to show for it!!!
Old Sep 13, 2010 | 10:27 PM
Damian's Avatar
LSX Mechanic
Yes sir, it does have the holes.
Old Sep 13, 2010 | 10:32 PM
beedo's Avatar
Better knock on wood before you attempt another swap! I have done a few swaps with nothing but the retainers holding the lifters up but I got paranoid and now I use the rods.
Old Sep 13, 2010 | 11:32 PM
kmracer's Avatar
i had the same thing happen to me, shitty harbour frieght magnets. sucked, i thought i was gonna have to pull the intake off. after fighting it for 2 hours i got it.
