Pat G high torque cam
Old Sep 14, 2010 | 03:17 PM
BR3W CITY's Avatar
Default Pat G high torque cam
I was reading the cam guide and came upon the Pat G "Torque coming out of my ears thread". The cam he was using was 224/228 .637/.639 110LSA (+0). Base on his results, it seems like it might be a good cam for my 6.0
I'll be running a stock 6.0, with nothing more than a set of headers in my 66 pickup. My short term plan is to keep the motor mostly stock aside from the cam/springs/tune. Probably be running a ~3600-4000 stall.
How do you think this cam will be for my application? Mostly a street machine, but would like to track it occasionally in summer. I am considering running some spray on track days. Thanks
Old Sep 14, 2010 | 03:28 PM
slt200mph's Avatar
I suggest that you send a PM to Patrick G ... he is the resident cam guru ..
Old Sep 14, 2010 | 03:42 PM
blsnelling's Avatar
I'm sure that cam was speced for exactly his compression and heads. I doubt you'd need that much lift on stock heads. You might want some advance ground into it as well, if you're not running as much compression.
Old Sep 14, 2010 | 05:25 PM
ss454327's Avatar
I'd go with the EPS 222/226 off the shelf cam for a TQ monster 6.0 myself.
Old Sep 14, 2010 | 05:47 PM
garygnu's Avatar
get good push rods ,and upgrade the rocker trunnions bearings.that is a custom cam,a custom cam is only $25 more.whats the weight of your truck?
Old Sep 14, 2010 | 05:55 PM
csv033's Avatar
224/228 600 lift is pretty common over here normally see around 300kw/390 hp in l92's its got a reasonable chop very good for a daily driver.
Old Sep 14, 2010 | 10:07 PM
BR3W CITY's Avatar
ive never officially weighed it. Its all steel, alum fuel cell, and no bed floor. Based on what others have reported, somewhere between 35-3800lbs. Some weigh less, as mine is a shortbed stepside its on the lighter end.
More info on the trunnion bearing thing please.
Old Sep 15, 2010 | 12:58 AM
01ssreda4's Avatar
search comp trunion upgrade
Old Sep 15, 2010 | 09:45 AM
slt200mph's Avatar
I run a similar cam to the Pat G cam with lower lift...224/228 .581/.588 110 + 0 ... with a set of TEA heads milled to 59 CC chanmbers which makes the compression 11.4 to 1 engine makes 350 ft. lbs. of TQ @ 3000 rpms and peaks at 418 ft. lbs. of TQ @ 4800 rpms...HP is 452..great street cam that makes plenty of muscle under the curve has a good lope and still gets 27 MPG on the highway...been running it now for 85,000 miles and really like it..
Old Sep 17, 2010 | 08:47 AM
BR3W CITY's Avatar
I looked at your setup a couple of times now slt200mph, but one of the issues I see is that I'm on stock 317's, putting my compression somewhere around 9.4:1 if I remember the stock figures correctly. I imagine my gains would come up a good chunk lower than yours with over a point less compression.
